Rules for dummies (to be exposed through OHcloud) from broadlink binding
Following this
I’ve endeavoured into rules scripting in OH for the first time.
These are my first ever rules, and the use case isn’t straight forward either (to me at least) - Please check the previous post if in need of more details regarding the funcionalities and the broadlink binding.
The objective is coherently integrating in openhab 3 rooms with the same kind of 433MHz controlled ceiling fan, which integrates a dimmable ceiling light, a fan and a led strip nightlight.
The following rules would affect my guinea pig room, once figured out, the other 2 rooms will be copy pasting+ swapping item names.
before importing them i feel i need to ask for help..
//all of the *_EXPitems are dummy items meant to be EXPosed via openhabcloud to google home
//translation from italian + other: luce=main light, ventilatore=ceiling fan, interruttore=z-wave wall switch, which is exposed
rule " switch off from the wall and reset"
    item Interruttore_Dario changed from ON to OFF
    if
      item Luce_Dario_EXP.state !=OFF
     item Luce_Dario_EXP.postUpdate(OFF)        //is this a valid way to update a dummy? is it post as in send or post as in latin for after?
    endif
    if item Ventilatore_Dario_EXP.state !=OFF
     item Ventilatore_Dario_EXP.postUpdate(OFF)
    endif
    if
      item Led_Dario_EXP.state !=OFF
      item Led_Dario_EXP.postUpdate(OFF)
    endif
    if
      item Dimmer_Dario_EXP.state !=OFF
      item Dimmer_Dario_EXP.postUpdate(OFF)
    endif
rule"switch on from the wall"
    item Interruttore_Dario changed from OFF to ON
    item Luce_Dario_EXP.postUpdate(ON)
rule"switch on from remote"
  while item Interruttore_Dario.state =OFF
      item Luce_Dario_EXP changed from OFF to ON
      Interruttore_Dario.sendCommand(ON)
    return;
      item Ventlatore_Dario_EXP changed from OFF to ON
      item Interruttore_Dario.sendCommand(ON)
      wait 0.5 sec                       //how to do it?
      RM3.sendCommand(Dario_Luce_Toggle) //switches off the light
      wait 0.2 sec                       //how?
      RM3.sendCommand(Dario_Vent_1)      //turns the fan ON
	  return;
      item Led_Dario_EXP changed from OFF to ON
      wait 0.2 sec                       //how?
      RM3.sendCommand(Dario_Led_On)      //turns the led ON
	  return;
      item Dimmer_Dario_EXP changed from OFF to ON
      RM3.sendCommand(Dario_Dimmer)      //light goes from 100 to 50
	  return;
rule"fan command while powered on"
  while
    item Interruttore_Dario.state =ON
      item Ventlatore_Dario_EXP changed from ON to OFF
      RM3.sendCommand(Dario_Vent_Off)    //turns the fan OFF
rule "dimmer command while powered on"
  while
       RM3.sendCommand(Dario_Dimmer)  //light goes from 100 to 50 OR quickly 0-100-50 if light off at the beginnng
      item Dimmer_Dario_EXP changed from ON to OFF
       RM3.sendCommand(Dario_Dimmer)  //light goes from 50 to 100
rule "led nightlight command while powered on"
  while
      RM3.sendCommand(Dario_Led_On)      //turns the led strip ON
        if
          wait 0.2 sec                      //how?
          RM3.sendCommand(Dario_Luce_Toggle) //switches the main light off
        endif
      item Dimmer_Dario_Exp.postupdate(OFF)
      item Led_Dario_EXP changed from ON to OFF
      RM3.sendCommand(Dario_Led_Off)    //turns the led OFF
rule"main light command while powered on"
  while
      item Luce_Dario_EXP changed from ON to OFF
        if
          item Dimmer_Dario_EXP state !=OFF
        endif
   when item Luce_Dario_EXP changed from OFF to ON
      RM3.sendCommand(Dario_Luce_Toggle) //switches on the light
        if
          item Led_Dario_EXP state !=OFF
          wait 0.2 sec
        endif
I don’t dare importing them directly as of yet due to a number of concearns:
  • I am struggling to envision whether one rule would trigger another and i’d end up in an infinite loop of light changes (ive tried to avoid it with item___postUpdate(___) but i feel very unsure about it
  • I don’t know how to have the system wait for half a second or so after the wall switch powers up the ceiling fans(they arent immediately operative when powered, and even z-wave sometimes varies in reaction speed)
  • generally insecure about the syntax. does endif exist, is it used correctly,is while used correctly, do i need to transform something into vars and strings… etc .. it’s the first time :baby:
  • do i need to import the map of hex strings from the binding ?
One last thing - i am sure there are ways to shrink the code significantly and render it more elegant. If they are needed to avoid unwanted interactions between rules, im’ all for it - Same if it is going to make me spare few MB of ram on the rpi.
But considering i can’t predict whether i’ll dabble with this kind of coding often or not (ideally if it works better not touch it), i’d like to be able to have it verbose enough to be able to make sense of it after not approaching it for few years.. this is maybe the beginners fear speaking tho.
:pray:t2: thanks in advance
In general, you may want to start much simpler, for example, just pick one action and implement it.
And you may need to read this chapter a few times:
Quit a few of your current questions and inevitable future questions are handled there.
Some more details:
Here a direct link to a sub-chapter of above that explains the difference between update and Command: Textual Rules | openHAB
That is a little more complicated, but here a good post about the options:
Understandable, the docs are not the greatest, there is a beginner section in the docs, read this please and especially this overview: https://www.openhab.org/docs/tutorial/rules.html
This one here:
if item Luce_Dario_EXP.state !=OFF
endif
will need to look like this:
if (Luce_Dario_EXP.state !=OFF)  {Luce_Dario_EXP.postUpdate(OFF)}
Note: if there is only one command you want to execute you can omit the {}
Happy reading and please start slow and small. A last tip: read up on the use of logInfo this will help you understand what your rules are doing and if they are doing anything.
AND: use VS Code Editors | openHAB it will highlight all syntax issues for you.
post deleted.
will bang my head and get there, than post for any other noob like me the replies that might be(or not) useful to them.
