Rules for T-Display with TASMOTA firmware
I want create wifi display for see the data of home. Now i work with one page .
My idea with button i want scroll more page and write this rules but dont work… where i wrong.
> var Contatore_pagina_display;
> if (Contatore_pagina_display > 4) {
>   Contatore_pagina_display = 0;
> } else {
>   if (Contatore_pagina_display == 1) {
>     val mqttActions = getActions("mqtt","mqtt:broker:fe55cd989c")
>     mqttActions.publishMQTT("cmnd/T-display/displaytext","[C65535Ozf1]Temperatura Esterna:[C63488c1l2f2s2p-4]"+ PrevisioniMeteo_OutdoorTemperature.state.toFullString)
>     mqttActions.publishMQTT("cmnd/T-display/displaytext","[C65535Oc1l10df1]Temperatura Cucina:[C63488c1l4f2s2p-4]"+
> sonoffTH16TempumidCucinaSwitchSensor_TH16TempumidCucinaSI7021Temperature.state.toFullString)
>     Contatore_pagina_display = Contatore_pagina_display + 1;
>   } else if (Contatore_pagina_display == 2) {
>      mqttActions.publishMQTT("cmnd/T-display/displaytext","[C65535Oc1l10df1]Temperatura Cucina:[C63488c1l4f2s2p-4]"+ sonoffTH16TempumidCucinaSwitchSensor_TH16TempumidCucinaSI7021Temperature.state.toFullString)
>   if (Contatore_pagina_display == 3) {
>   } else if (Contatore_pagina_display == 4) {
Please use code fences, otherwise it’s impossible to understand your rule
And after that: What exactly are you trying?
I’ve understood that you want to have a rule that shall display different content on a certain value of your variable “contatore_pagina_display” correct?
Where shall the above code run? Is it a rule, is it a script? What is calling that script?
Are you running on openHAB 2 or openHAB 3?
Which userinterface (MainUI, BasicUI, Habpanel) are you using on your display?
Is this button linked in some way to the variable Contatore_pagina_display?
and thanks for the reply.
I am using oh3 with mainUI the display is connected to an esp32 with tasmota firmware and communicates with openhab through MQTT. On the display at the moment I was able to see a page with two sensor temperatures. With the following code:
Now My aim now is to press a button on esp32 that activates the rule and increments the variable “counter_pagina_display” in order to display more pages and more data.
The my try (with 5 same page) but dont work
triggers:
  - id: "1"
    configuration:
      itemName: Tdisplay1TasmotaSwitchSensor_state
conditions: []
actions:
  - inputs: {}
    configuration:
      type: application/vnd.openhab.dsl.rule
      script: >
        } else {
    type: script.ScriptAction
The idea was to activate the rule every change of the phisical button in order to enter the rule and increase the variable “Contatore_pagina_display” by 1
Ah, but every time you start the rule you create a new Contatore_pagina_display empty variable.
In a DSL rules file,you might use a global variable. But you can’t do that in a UI DSL rule.
You could use an Item of course, which survive between runs of the rule.
I have a doubt : The rules that work i made with rules (1 page):
senza script
regola senza script
for test i made same rules 1 page in script and dont work, MQTT comand dont work in script or i wrong something
regola script
I net try i convert rules simple (1page) in to script (1page) :slight_smile:
rule "Gestione T-display"
    Item Tdisplay1TasmotaSwitchSensor_state changed to OPEN
In this way dont work
I try to simplyfy code in
    mqttActions.publishMQTT("cmnd/T-display/displaytext","Temperatura Esterna:")
DONT WORK
IT IS MEANS THAT mqttActions.publishMQTT dont work in script-??? work only in rules page .
HELP
If in the script page i remove all and write only:
IT IS WORK
Why, what does it do? Show an error in your openhab.log? Publish a message that you didn’t expect? Is your rule ever triggered? You could add a log message to find out. Is your rules file even loaded? Again, your openhab.log will tell you. Did you put it in the right folder? It’s a rule, not a script.
LOg file :slight_smile:
2021-04-17 17:53:25.898 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'f3300ba980' failed: rule "Gestione T-display"
        val actions = getActions("mqtt","mqtt:broker:fe55cd989c")
        actions.publishMQTT("cmnd/T-display/displaytext","[C65535Ozf1]Temperatura Esterna:[C63488c1l2f2s2p-4]"+ PrevisioniMeteo_OutdoorTemperature.state.toFullString)
        actions.publishMQTT("cmnd/T-display/displaytext","[C65535Oc1l10df1]Temperatura Cucina:[C63488c1l4f2s2p-4]"+ sonoffTH16TempumidCucinaSwitchSensor_TH16TempumidCucinaSI7021Temperature.state.toFullString)
end)
other
2021-04-17 17:55:13.303 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'f3300ba980' failed:  ___ rule  ___ "Gestione T-display"
        Item Tdisplay1TasmotaSwitchSensor_st ___ ate c ___ hanged to OPEN
   1. The method or field rule is undefined; line 1, column 0, length 4
   2. The method or field when is undefined; line 2, column 31, length 4
   3. The method or field changed is undefined; line 3, column 84, length 7
   4. The method or field to is undefined; line 3, column 92, length 2
   5. The method or field then is undefined; line 4, column 104, length 4
   6. The method or field end is undefined; line 8, column 557, length 3
   7. This expression is not allowed in this context, since it doesn't cause any side effects.; line 1, column 5, length 20
   8. This expression is not allowed in this context, since it doesn't cause any side effects.; line 3, column 44, length 4
   9. This expression is not allowed in this context, since it doesn't cause any side effects.; line 3, column 49, length 34
   10. This expression is not allowed in this context, since it doesn't cause any side effects.; line 3, column 95, length 4
You have to put rules in a rules file named whatever.rules, and you have to put the file in a folder /rules that should already exist and hold a readme.txt file.
If this is all too complicated, stay with your UI rule but use an Item as your long-lived counter.
