n00b
(andreas)
October 29, 2023, 11:17am
1
Hi there,
I’m on OpenHAB 4.0.3 and I’m failing to achieve the following:
I’m using a awtrix light pixel clock and now I want to show some information of my OpenHAB items within it. I successfully created the MQTT item to send information successfully, but now I want so send the state of another item as the command.
This is working as a rule:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: LocalWeatherandForecast_Aussentemperatur
conditions: []
actions:
- inputs: {}
configuration:
command: "{ 'icon':73, 'text':'28°C' }"
itemName: PixelClocks_weather_livingroom
type: core.ItemCommandAction
as the temperature is “hardcoded” for my mqtt tests. But if I try to send the value of the actual item it is also only send as text. Here is the code:
configuration: {}
triggers:
- id: "1"
configuration:
conditions: []
actions:
- inputs: {}
configuration:
command: "{ 'icon':73, 'text':(LocalWeatherandForecast_Aussentemperatur.state) }"
Can anyone help me with this? I don’t get any error in the openhab log…
JimT
(jimtng)
October 29, 2023, 11:57am
2
You’ll need to use a scripting language for this I think.
For example you can use RulesDSL, although I’d suggest jruby or javascript but its corresponding addon needs to be installed first.
val output = "{ 'icon':73, 'text':'" + LocalWeatherandForecast_Aussentemperatur.state + "' }"
PixelClocks_weather_livingroom.sendCommand(output)
Jruby:
output = "{ 'icon':73, 'text':'#{LocalWeatherandForecast_Aussentemperatur.state}' }"
PixelClocks_weather_livingroom.command(output)
So the whole thing looks like:
configuration: {}
triggers:
- id: "1"
configuration:
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: |-
type: script.ScriptAction
n00b
(andreas)
October 29, 2023, 12:08pm
3
Thank you so much! You made my day!!!
JimT
(jimtng)
October 29, 2023, 12:13pm
4
A better option / solution would be to redefine your MQTT item. Can you paste me the item definition for PixelClocks_weather_livingroom
n00b
(andreas)
October 29, 2023, 12:19pm
5
If I would know how to paste it…
I defined a MQTT Thing with a channel, which I linked to the item PixelClocks_weather_livingroom…
But the code is only:
label: weather
type: String
category: display
groupNames: []
groupType: None
function: null
tags:
- Point
I guess, that’s NOT what you are asking for…
JimT
(jimtng)
October 29, 2023, 12:39pm
6
I just realised, what I want is the Thing / channel definition, not the item definition.
Something like this (just to help you find the right one). It needs to have UID: mqtt:topic:xx:xxxx
UID: mqtt:topic:mosquitto:aaa
label: Generic MQTT Thing
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:mosquitto
channels:
- id: textdata
channelTypeUID: mqtt:string
label: label
description: ""
configuration:
stateTopic: device/state
commandTopic: device/command
n00b
(andreas)
October 29, 2023, 12:48pm
7
Here it is (please note that I added already more as your initial post works):
UID: mqtt:topic:1671786fee
label: PixelClocks
configuration: {}
bridgeUID: mqtt:broker:cce5679735
channels:
- id: pixelclockLivingRoomWeather
label: weather
description: Shows Temperature delivered by OpenWeather on PixelClock
configuration:
commandTopic: awtrix_livingroom/custom/weather
- id: pixelclockLivingroomPower
label: livingroomPower
description: Power usage of house displayed on Living room Pixelclock
configuration:
commandTopic: awtrix_livingroom/custom/power
- id: livingRoom_TempHum
label: livingroomTempHum
description: Information about the living room temperature and humidity on
livingroom pixel clock
configuration:
commandTopic: awtrix_livingroom/custom/room
JimT
(jimtng)
October 29, 2023, 12:59pm
8
OK so you can basically add this to your channel:
formatBeforePublish: "{ 'icon':73, 'text':'%s' }"
And then the rule can be made simpler, like this:
configuration: {}
triggers:
- id: "1"
configuration:
conditions: []
actions:
- inputs: {}
configuration:
script: |-
PixelClocks_weather_livingroom.sendCommand(LocalWeatherandForecast_Aussentemperatur.state.toString)
Just another option to consider.
n00b
(andreas)
October 29, 2023, 3:44pm
9
Wow, thank you very much!!!
