I am running openhabian on a rpbi4, using a usb-attached ssd since 2 years (os is booting and running from the usb-ssd - device is pretty well in shape).
I am regular running apt-get update & apt-get upgrade manually.
as stated, using openhabian.
The timer-object just stopped to work, it stays at “null”.
If you didn’t change anything, the only thing I can think of is that your variable is uppercase Timer and your rule refers to a lowercase timer. I don’t know why that would work and then suddenly not work, though.
Good ideas - I spent the weekend into it and was near madness, as I wasn’t able to detect any configuration-drift on my side (I am also using a private git-repo to persist my configurations).
Apparently someone “stole” my smart-light in the guest-toilet - I checked my zigbee2mqtt-server and the light itself was also there gone (many neighbours here).
Fortunately I have a hue remote around exactly for this case (pressing the I and O buttons near a zigbee-device for ~5secs will factory-reset it).
Due this, zigbee2mqtt was able to fetch this light again and openhab is now able again to run timer against it.
btw, “stealing” of zigbee-devices doesnt seem to be uncommon. My zigbee2mqtt-server has connected to at least seven zigbee-devices in the last 6months definately no in my ownership. If Hue- and Alexa-bridges are also this greedy, no wonder devices vanish before you could claim it
nah, much worse.
I have checked my logs, and apparently the item used for the toilet-light received an OTA-update.
this was like a factory reset.
afterwards it registered in the zigbee-network of someone else (either neighbour above or left).
the timer itself worked well, but on a thing / item not under control of openhab anymore.
zigbee2mqtt users have to be aware of this, but it was not a openhab-issue.
