Not that I can tell based on a reading of the wiki page. You can set a refresh_interval which will poll the device for changes, set a polling rule and if the item doesn’t receive an update after the polling period you will know it isn’t responding.
rule "Is light responding"
Time cron "0/10 * * * ? *"
if(light.lastupdate < now.minusSeconds(10)) {
// it has been more than 10 seconds since light was updated
This requires persistence to work. I don’t know if you can compare light.lastUpdate and now like that, you may need to play around with it to get the right way (e.g. light.lastUpdate.calendar < now.minusSeconds(10).calendar). You will probably also want to add some logic to avoid it sending you an email every 10 seconds when a node does go offline.
var Timer S01D001_tAlive = null
rule "S01D001 Alive"
Item S01D001_tLastUpdate changed
S01D001_cAlive.postUpdate(OPEN) // OPEN = TRUE
S01D001_tAlive?.cancel()
S01D001_tAlive = createTimer(now.plusHours(1)) [|
logWarn("S01", "S01D001 appears to be dead")
S01D001_cAlive.postUpdate(CLOSED) // CLOSED = FALSE
sitemap
sitemap S01 label="System 01 - Z-Wave" {
Frame label="Devices" {
Text item=S01D001_tLastUpdate label="S01D001 - Motion sensor [%1$td.%1$tm.%1$tY %1$tT]" valuecolor=[S01D001_cAlive==OPEN="GREEN", S01D001_cAlive==CLOSED="RED"] icon="my_clock" {
Frame label="Internal" {
Text item=S01D001_cMotion label="Motion [%s]" icon="contact"
Text item=S01D001_nTemperature label="Temperature [%.1f °C]" icon="temperature"
Text item=S01D001_nIlluminance label="Illuminance [%.2f lux]" icon="light-on"
Text item=S01D001_nBattery label="Battery [%d %%]" icon="my_battery"
Text item=S01D001_cAlarm label="Alarm [%s]" icon="contact"
Frame label="Utility" {
Text item=S01D001_tLastUpdate label="Last update [%1$td.%1$tm.%1$tY %1$tT]" icon="my_clock"
Text item=S01D001_cAlive label="Alive [%s]" icon="contact"
Some notes:
The prefix ‘S01D001’ is just my own naming convention for devices. ‘S01’ denotes System 01 (which is Z-Wave) and D001 device number 1 within this system.
For brevity I have only shown the setup for one device above. Obviously I am using the same for all the other devices as well (i.e. S01D002, S01D003, etc.).
The value of the timer that is used to detect offline nodes (1 hour in the example above) must be tuned for each device, according to their internal settings for publish/wakeup, etc. I have found 1 hour to work well for all my devices, except a garage door tilt sensor that I needed to set to 1,5 hours.
Hope this helps!
Ps! I am sure someone could find a clever way of collapsing this system a bit (in the case of several devices) by using groups and/or lambda functions. Myself I have not taken the step into this jungle just yet…
This timer based approach is pretty good in the generic case as well. It’s kind of a dead man’s switch. If you don’t hear from the item after a certain amount of time mark it dead. It works best for items that report periodically.
I made a group called gNodes now and trying to migrate it over like we did with the door alerts and alert.apply but it dont seem to like it.
rule "DeadNodeCheck"
Item gNodes received update
logInfo("Status", "NODE GROUP CHECK: Checking Node Status.")
gNodes_tAlive?.cancel()
gNodes_tAlive = createTimer(now.plusHours(1)) [|
alert.apply(gNodes, "- Dead Node")
and…
val Functions$Function2 alert = [GroupItem g, String type |
val latest = g.members.sortBy[lastUpdate].last
val name = latest.name.split("_")
Notification_Proxy.postUpdate(name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + type + " Alert!. " + latest.state.toString)
rule "Dispatch Notification"
Item Notification_Proxy received update
logWarn("Notification", Notification_Proxy.state.toString)
sendMail("alerts@cidcomm.com", "Security System Alert!", Notification_Proxy.state.toString)
but throwing…
2016-05-25 13:55:48.338 [WARN ] [m.s.internal.actions.TimerImpl] - An error occured while cancelling the job 'DEFAULT.2016-05-25T14:55:48.316-04:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@f00553 (explicitSyntax: true)': Unable to unschedule trigger [DEFAULT.6da64b5bd2ee-d2926540-d86c-43cb-b862-ce961a521ee3] while deleting job [DEFAULT.2016-05-25T14:55:48.316-04:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@f00553 (explicitSyntax: true)]
and…
2016-05-25 13:57:48.454 [ERROR] [script.actions.ScriptExecution] - Failed to schedule code for execution.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'DEFAULT.2016-05-25T14:57:48.383-04:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@16a9b00 (explicitSyntax: true)', because one already exists with this identification.
at org.quartz.simpl.RAMJobStore.storeJob(RAMJobStore.java:277) ~[na:na]
at org.quartz.simpl.RAMJobStore.storeJobAndTrigger(RAMJobStore.java:249) ~[na:na]
at org.quartz.core.QuartzScheduler.scheduleJob(QuartzScheduler.java:840) ~[na:na]
at org.quartz.impl.StdScheduler.scheduleJob(StdScheduler.java:250) ~[quartz-all-2.1.7.jar:na]
at org.openhab.model.script.actions.ScriptExecution.makeTimer(ScriptExecution.java:130) [org.openhab.model.script_1.8.2.jar:na]
at org.openhab.model.script.actions.ScriptExecution.createTimer(ScriptExecution.java:92) [org.openhab.model.script_1.8.2.jar:na]
at sun.reflect.GeneratedMethodAccessor296.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_101]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_101]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor283.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) [org.openhab.model.script_1.8.2.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor284.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(XbaseInterpreter.java:843) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor292.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor287.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) [org.openhab.model.script_1.8.2.jar:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) [org.openhab.core.scriptengine_1.8.2.jar:na]
