Hello
All my rules in the javascript language are not working.
Has anyone had the same problem? At least the two error messages below show that the “rule”-UID is undefined. So the variable ctx does not return this value!?
Example code:
x = new Date();
h = x.getHours();
logger.info("Current hour: "+h);
var currentStatus = itemRegistry.getItem("test").getState();
Everything is working, except access of itemRegistry (the last line in my code).
Error logs:
2021-08-13 23:11:28.225 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
2021-08-13 23:11:28.241 [INFO ] [org.openhab.rule.undefined ] - Current hour: 23
2021-08-13 23:11:28.246 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
