RulesEditor for habpanel
https://community.openhab.org/t/template-widget-tutorial-examples-make-your-own-widget/14211/190
Creating new topic for @Meghana_N question regarding providing Ruleseditor functionality in habpanel.
From the sourcecode of habpanel, each widget is calling getItems() function to load items as below.
WidgetSettingsCtrlLabel.$inject = [‘$scope’, ‘$timeout’, ‘$rootScope’, ‘$uibModalInstance’, ‘widget’, ‘OHService’];
function WidgetSettingsCtrlLabel($scope, $timeout, $rootScope, $modalInstance, widget, OHService) {
    $scope.widget = widget;
    $scope.items = OHService.getItems();
    $scope.form = {
        sizeX: widget.sizeX,
        sizeY: widget.sizeY,
        col: widget.col,
        row: widget.row,
        background: widget.background,
        foreground: widget.foreground,
        font_size: widget.font_size
@Meghana_N, you need to add code as in reloadItems function (registed in openhab.service.js file) (internally calls loadItems) which is called while dashboard display as below.
You can see Custom widget setting for item-picker.
<item-picker ng-switch-when="item" ng-model="form.config[setting.id]"></item-picker>
