Hey guys,
I have a Raspberry Pi Ultrasonic sensor, I want to measure the distance from the top of the cat-feeding-Automation-tank to the bottom, to find out how much food is still in it.
I saved it in /home/Sensor_Script.py
This is the Log error
[21:06:59] openhabian@openhab : /home $ python3 Sensor_Script.py
Traceback (most recent call last):
File “Sensor_Script.py”, line 52, in
abstand = distanz()
File “Sensor_Script.py”, line 22, in distanz
GPIO.output(GPIO_TRIGGER, True)
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
This is the Script
#Bibliotheken einbinden
import RPi.GPIO as GPIO
import time
import random
import statistics
from statistics import mean
##GPIO Modus (BOARD / BCM)
GPIO.setwarnings(False)
GPIO.cleanup()
#GPIO Pins zuweisen
GPIO_TRIGGER = 6
GPIO_ECHO = 25
n=5
#Richtung der GPIO-Pins festlegen (IN / OUT)
GPIO.setup(GPIO_TRIGGER, GPIO.OUT)
GPIO.setup(GPIO_ECHO, GPIO.IN)
def distanz():
# setze Trigger auf HIGH
# setze Trigger nach 0.01ms aus LOW
time.sleep(0.00001)
GPIO.output(GPIO_TRIGGER, False)
StartZeit = time.time()
StopZeit = time.time()
speichere Startzeit
while GPIO.input(GPIO_ECHO) == 0:
speichere Ankunftszeit
while GPIO.input(GPIO_ECHO) == 1:
Zeit Differenz zwischen Start und Ankunft
TimeElapsed = StopZeit - StartZeit
mit der Schallgeschwindigkeit (34300 cm/s) multiplizieren
und durch 2 teilen, da hin und zurueck
distanz = (TimeElapsed * 34300) / 2
return distanz
Messwerte = []
while True:
for i in range(n):
abstand = distanz()
Messwerte.append(abstand)
time.sleep(1)
GPIO.cleanup()
print(Messwerte)
print(statistics.stdev(Messwerte))
if statistics.stdev(Messwerte) <= 10:
print(“fertig”)
avg = mean(Messwerte)
print(round(avg,2))
break
else:
Messwerte.clear()
