now I found the time to try this out. It seems to me that installation went ok (only tried the gateway version, not bluetooth). Listing the running bundles gives me:
openhab> bundle:list -l | grep ruuvi
306 x Resolved x 80 x 5.1.0.202511110426 x mvn:org.openhab.addons.bundles/org.openhab.binding.bluetooth.ruuvitag/5.1.0-SNAPSHOT
318 x Resolved x 82 x 5.1.0.202511110428 x mvn:org.openhab.addons.bundles/org.openhab.binding.mqtt.ruuvigateway/5.1.0-SNAPSHOT
350 x Active x 80 x 5.1.0.202511091035 x file:/openhab/addons/org.openhab.binding.mqtt.ruuvigateway-5.1.0-SNAPSHOT.jar
However when adding a new Thing under MQTT binding, it only gives me RuuviTag smart beacon. Should Air appear in the list as well?
I haven’t installed JAR bindings manually since 2.x, so it might be that I’m missing something important as well.
@siest4 good question! I should have linked the READMEs. The readmes are now linked to the github release page.
It is kept as a single thing for now so indeed it is the same. Only the channels that are sent by the device have values.
Discovery should work automatically with both bluetooth and mqtt…although at least on my computer the whole bluetooth discovery was flaky (I concluded it unrelated to the ruuvi, more likely a system issue with my computer).
When adding manually, you need to create the thing using the bluetooth MAC address of the sensor.
Tried it now - seems I confused the thing types initially because I had both versions of the binding running and didn’t see Air’s measurement channels there. Now it seems to work! I didn’t manage to get scanning working, so I added the thing manually with Air’s MQTT topic.
Yes, it’s the default one, ruuvi/. I can try it again later if you like. I just didn’t invest too much time in it as it’s so easy to configure manually.
