Ruuvi Gateway MQTT binding
This binding allows integration of Ruuvi Tags via MQTT data, as collected by Ruuvi Gateway.
Requires OpenHAB 3.4.0-M1 or newer
Ruuvi gateway is listening for Bluetooth advertisements and publishing that data over MQTT.
Compared to Ruuvi Tag Bluetooth binding, this binding has the benefit of relying on strong and reliable antenna of Ruuvi Gateway, as opposed to e.g. usually much weaker antenna integrated onto computer motherboard.
Ruuvi Cloud Subscription is not needed at all as the integration is local.
Both RuuviTag and RuuviTag Pro are supported.
Full Readme: openhab2-addons/bundles/org.openhab.binding.mqtt.ruuvigateway/README.md at ruuvitaggw · ssalonen/openhab2-addons · GitHub
logo
Installation
Marketplace plugin not supported anymore. This functionality is available as part of the mqtt addon bundle, installable via openHAB Web UI.
Hi all!
Thank you Ssalonen for the work for the plugin!
I am fairly new to openHab and installed openhabian with openHAB 4.1.2 on RaspberryPi 4. I was able to setup Moquitto MQTT Servce and setup Ruuvi Gateway to publish messages to ruuvi/# topic. I have also setup MQTT broker Thing and Ruuvi Gateway MQTT binding. I have also one Ruuvi Tab configured using the Broker as Parent Bridge.
I can see from the log that data is received by the MQTT Broker. If i enable channel on the broker I will get all messages, but the problem is that the Tag is not receiving any data and the Status will go to OFFLINE after timeout. I would greatly appreciate if someone knows what is going wrong here. Is there some communication issue or could the problem be with openHab 4.
There is the tag config:
UID: mqtt:ruuvitag_beacon:dcbdc7eb01:RuuviTag_Ulkovarasto
label: RuuviTag SmartBeacon
thingTypeUID: mqtt:ruuvitag_beacon
configuration:
  topic: ruuvi/EF:91:F3:24:DE:88
bridgeUID: mqtt:broker:dcbdc7eb01
channels:
  - id: rssi
    channelTypeUID: mqtt:ruuvitag_rssi
    label: RSSI
    description: Received signal strength indicator
    configuration: {}
  - id: ts
    channelTypeUID: mqtt:ruuvitag_ts
    label: Timestamp
    description: Timestamp when the message from Bluetooth sensor was received by
      Gateway (ts)
    configuration: {}
  - id: gwts
    channelTypeUID: mqtt:ruuvitag_gwts
    label: Relay Timestamp
    description: Timestamp when the message from Bluetooth sensor was relayed by
      Gateway (gwts)
    configuration: {}
  - id: gwmac
    channelTypeUID: mqtt:ruuvitag_gwmac
    label: Gateway MAC Address
    description: MAC-address of Ruuvi Gateway
    configuration: {}
  - id: accelerationx
    channelTypeUID: mqtt:ruuvitag_accelerationx
    label: Acceleration X
    description: null
    configuration: {}
  - id: accelerationy
    channelTypeUID: mqtt:ruuvitag_accelerationy
    label: Acceleration Y
    description: null
    configuration: {}
  - id: accelerationz
    channelTypeUID: mqtt:ruuvitag_accelerationz
    label: Acceleration Z
    description: null
    configuration: {}
  - id: batteryVoltage
    channelTypeUID: mqtt:ruuvitag_batteryVoltage
    label: Battery Voltage
    description: null
    configuration: {}
  - id: dataFormat
    channelTypeUID: mqtt:ruuvitag_dataFormat
    label: Data Format Version
    description: null
    configuration: {}
  - id: humidity
    channelTypeUID: mqtt:ruuvitag_humidity
    label: Humidity
    description: null
    configuration: {}
  - id: measurementSequenceNumber
    channelTypeUID: mqtt:ruuvitag_measurementSequenceNumber
    label: Measurement Sequence Number
    description: null
    configuration: {}
  - id: movementCounter
    channelTypeUID: mqtt:ruuvitag_movementCounter
    label: Movement Counter
    description: null
    configuration: {}
  - id: pressure
    channelTypeUID: mqtt:ruuvitag_pressure
    label: Pressure
    description: null
    configuration: {}
  - id: temperature
    channelTypeUID: mqtt:ruuvitag_temperature
    label: Temperature
    description: null
    configuration: {}
  - id: txPower
    channelTypeUID: mqtt:ruuvitag_txPower
    label: TX Power
    description: null
    configuration: {}
Here is the log after restarting MQTT Broker:
09:38:12.730 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.ruuvigateway.internal.discovery.RuuviGatewayDiscoveryService@18eeac7 to discovery topic ruuvi/# on broker mqtt:broker:dcbdc7eb01
09:38:12.733 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.ruuvigateway.internal.discovery.RuuviGatewayDiscoveryService@a225e5 to discovery topic ruuvi/# on broker mqtt:broker:dcbdc7eb01
09:38:12.733 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@7385d9 to discovery topic +/+/$homie on broker mqtt:broker:dcbdc7eb01
09:38:12.733 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:dcbdc7eb01' changed from OFFLINE to ONLINE
09:38:12.738 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:ruuvitag_beacon:dcbdc7eb01:RuuviTag_Ulkovarasto' changed from INITIALIZING to UNKNOWN
09:38:12.740 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.espmilighthub.internal.discovery.EspMilightHubDiscoveryService@1b2bb62 to discovery topic milight/states/# on broker mqtt:broker:dcbdc7eb01
09:38:12.782 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:ruuvitag_beacon:dcbdc7eb01:RuuviTag_Ulkovarasto' changed from UNKNOWN to ONLINE: Waiting for initial data
And here is the Channel data when enabling on MQTT Broker Thing for the tag:
09:56:21.331 [INFO ] [openhab.event.ChannelTriggeredEvent  ] - mqtt:broker:dcbdc7eb01:mqtt_ruuvi_publish triggered {
	"gw_mac":	"D7:CC:D7:0D:D9:05",
	"rssi":	-73,
	"aoa":	[],
	"gwts":	"1714809381",
	"ts":	"1714809381",
	"data":	"0201061BFF99040509FA5127C76AFC3401380004A9361AF94EEF91F324DE88",
	"coords":	""
09:56:44.463 [INFO ] [openhab.event.ChannelTriggeredEvent  ] - mqtt:broker:dcbdc7eb01:mqtt_ruuvi_publish triggered {
	"rssi":	-75,
	"aoa":	[],
	"gwts":	"1714809404",
	"ts":	"1714809404",
	"data":	"0201061BFF99040509FA5129C76BFC340138FFF4A9361AF957EF91F324DE88",
	"coords":	""
How did you install the mqtt addon? I just noticed that this Marketplace entry (this thread) was still “published” even though the code already got merged, and the addon is available as an official addon.If you installed this Ruuvi Gateway MQTT addon via Community marketplace, please uninstall it and install MQTT addon instead using the Web UI.
Did you configure the ruuvi thing manually? I highly suggest using discovery / thing inbox instead (see screenshot below, red INBOX button at the bottom), see docs Ruuvi Gateway MQTT - Bindings | openHAB
I suspect it possible that configured mqtt topic is slightly off (default, see below, in ruuvi gateway is ruuvi/gateway-mac/ruuvi-tag-mac). My auto-discoverd ruuvi tag looks like below (mac addresses redacted/censored)
UID: mqtt:ruuvitag_beacon:4800000000:c90000000000
label: MQTT Ruuvi Tag C9:00:00:00:00:00
configuration:
  topic: ruuvi/D8:00:00:00:00:00/C9:00:00:00:00:00
bridgeUID: mqtt:broker:4800000000
channels:
  - id: rssi
    label: RSSI
    configuration: {}
If things do not work out after checking mqtt addon installation, and utilizing thing auto-discovery, please comment here and we can troubleshoot further with logs.
@ttolvanen any luck?
as Ruuvi has recently introdudced a new product in their line called Ruuvi Air (an air quality monitor), are there any plans to add support for it to the MQTT binding? I’ve got one and am happy to be a beta tester if needed. :slightly_smiling_face:
Hi! Yes that would be very nice to see Air support!
I reached out to Ruuvi if they would like to sponsor the device so it would be easier to develop the support
Nice! Hoping they are willing to do that. Also, if you need any example MQTT payloads from Gateway, I can provide those. To me they look very similar to what Ruuvi Tags send.
Just got a reply they will send a unit! Stay tuned!
Placeholder ticket created Ruuvi Air support · Issue #19608 · openhab/openhab-addons · GitHub
OK I have the first implementation ready and my local tests are promising… You can find it here for testing (please report any issues there):
