Thanks for your reply.
Yes, I did more than one trial and I am using the default user openhabian. I run openHAB with about 50 things and 350 items. Except for Samba, I have not experienced any problems.
In openhab.log
are only errors which I do understand (some stuff about rules or transformations).
In syslog
I found the following lines, but I don’t know if they are Samba related:
Feb 17 06:25:01 openhabian exim4: ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system possibly broken
Feb 17 07:06:24 openhabian systemd[1]: Started Session 4039 of user openhabian.
Feb 17 07:06:49 openhabian kernel: [2022358.986471] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
Feb 17 07:06:58 openhabian kernel: [2022368.140471] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
Feb 17 07:07:06 openhabian kernel: [2022376.333628] blk_update_request: I/O error, dev mmcblk0, sector 5450898 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:14 openhabian kernel: [2022384.525612] blk_update_request: I/O error, dev mmcblk0, sector 5450899 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:23 openhabian kernel: [2022392.717572] blk_update_request: I/O error, dev mmcblk0, sector 5450900 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:31 openhabian kernel: [2022400.909643] blk_update_request: I/O error, dev mmcblk0, sector 5450901 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:39 openhabian kernel: [2022409.101626] blk_update_request: I/O error, dev mmcblk0, sector 5450902 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:47 openhabian kernel: [2022417.293624] blk_update_request: I/O error, dev mmcblk0, sector 5450903 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:07:56 openhabian kernel: [2022426.205461] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
Feb 17 07:08:05 openhabian kernel: [2022434.874452] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
Feb 17 07:08:13 openhabian kernel: [2022443.067594] blk_update_request: I/O error, dev mmcblk0, sector 5450898 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:08:21 openhabian kernel: [2022451.259636] blk_update_request: I/O error, dev mmcblk0, sector 5450899 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:08:29 openhabian kernel: [2022459.451602] blk_update_request: I/O error, dev mmcblk0, sector 5450900 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:08:37 openhabian kernel: [2022467.643611] blk_update_request: I/O error, dev mmcblk0, sector 5450901 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:08:46 openhabian kernel: [2022475.835627] blk_update_request: I/O error, dev mmcblk0, sector 5450902 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
Feb 17 07:08:54 openhabian kernel: [2022484.027643] blk_update_request: I/O error, dev mmcblk0, sector 5450903 op 0x0:(READ) flags 0x0 phys_
seg 1 prio class 0
with sudo dmesg
I found a lot of stuff like this:
[1984383.101751] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
[1984391.296747] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
[1984399.489913] blk_update_request: I/O error, dev mmcblk0, sector 5450898 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[1984407.681890] blk_update_request: I/O error, dev mmcblk0, sector 5450899 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[1984415.873901] blk_update_request: I/O error, dev mmcblk0, sector 5450900 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[1984424.065890] blk_update_request: I/O error, dev mmcblk0, sector 5450901 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[1984425.143976] INFO: task kworker/0:1:29447 blocked for more than 122 seconds.
[1984425.143997] Tainted: G C 5.10.103-v7l+ #1529
[1984425.144013] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
sudo smbpasswd -e openhabian
did not work. The only output was as following:
openhabian@openhabian:~ $ sudo smbpasswd -e openhabian
Bus error
