Hi guys,
I have 8 Xiaomi Temperature, Pressure and Humidity Sensors around and just upgraded to OpenHAB 2.5.4 Release Build (I was on 2.4)
I noticed that some of my air pressure readings of those sensors now show “kPa” and some show “hPa” as units. They are the same sensors, no difference in configuration or item setup. How can this be (fixed)?
See screenshot:
Item setup:
//Serverroom
Number:Temperature XHTP01_Temperature "Temperature" <temperature> { channel="mihome:sensor_weather_v1:158d00025d8b50:temperature" }
Number:Dimensionless XHTP01_Humidity "Humidity" <humidity> { channel="mihome:sensor_weather_v1:158d00025d8b50:humidity" }
Number:Pressure XHTP01_Pressure "Pressure" <pressure> { channel="mihome:sensor_weather_v1:158d00025d8b50:pressure" }
Number XHTP01_Battery "HTP Sensor #1 Battery [%s %%]" <battery> { channel="mihome:sensor_weather_v1:158d00025d8b50:batteryLevel" }
Switch XHTP01_BatteryLow "HTP Sensor #1 Battery Low [%s]" <radiobutton> { channel="mihome:sensor_weather_v1:158d00025d8b50:lowBattery" }
//Bedroom
Number:Temperature XHTP02_Temperature "Temperature" <temperature> { channel="mihome:sensor_weather_v1:158d0002c1294a:temperature" }
Number:Dimensionless XHTP02_Humidity "Humidity" <humidity> { channel="mihome:sensor_weather_v1:158d0002c1294a:humidity" }
Number:Pressure XHTP02_Pressure "Pressure" <pressure> { channel="mihome:sensor_weather_v1:158d0002c1294a:pressure" }
Number XHTP02_Battery "HTP Sensor #2 Battery [%s %%]" <battery> { channel="mihome:sensor_weather_v1:158d0002c1294a:batteryLevel" }
Switch XHTP02_BatteryLow "HTP Sensor #2 Battery Low [%s]" <radiobutton> { channel="mihome:sensor_weather_v1:158d0002c1294a:lowBattery" }
Sitemap:
Frame label="Current Air Pressure" icon="pressure" {
Text item=XHTP01_Pressure label="Serverroom" icon="serverroom"
Text item=XHTP02_Pressure label="Bedroom" icon="bedroom"
Text item=XHTP03_Pressure label="Livingroom" icon="sofa"
Text item=XHTP04_Pressure label="Bathroom" icon="bath"
Text item=XHTP05_Pressure label="Balcony" icon="terrace"
Text item=XHTP06_Pressure label="Workbench" icon="workbench"
Text item=XHTP07_Pressure label="Attic" icon="attic"
Text item=XHTP08_Pressure label="Guest Bedroom" icon="bedroom"
Text item=XHTP09_Pressure label="HiFi Rack" icon="receiver"
EDIT:
Just noticed, same for the Humidity. Some show unit “one” (?) and some show “%”
