I hope you can help me with this error:
15:12:07.665 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'iMultimedia_SmartTV_Source_Name' received command HDMI1/DVI
15:12:07.686 [ERROR] [ge.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
15:12:07.689 [WARN ] [gtv.internal.handler.SamsungTvHandler] - Channel 'samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:sourceName' not supported
15:12:07.689 [INFO ] [arthome.event.ItemStatePredictedEvent] - iMultimedia_SmartTV_Source_Name predicted to become HDMI1/DVI
15:12:07.697 [INFO ] [smarthome.event.ItemStateChangedEvent] - iMultimedia_SmartTV_Source_Name changed from HDMI3 to HDMI1/DVI
15:12:15.772 [INFO ] [smarthome.event.ItemStateChangedEvent] - OpenHABVM_Memory_Used changed from 3078 to 3079
It`s an Samsung UE55MU6179U if it will be important. I use OpenHAB 2.5.12 and the Binding is also in the version 2.5.12.
Here my items file:
//Samsung Smart TV
Group gMultimedia_SmartTV "SmartTV" <screen> (gMultimedia)
Dimmer iMultimedia_SmartTV_Volume "Lautstärke ändern" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:volume"}
Switch iMultimedia_SmartTV_Mute "Stumm schalten" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:mute"}
String iMultimedia_SmartTV_Source_Name "Quellenname" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:sourceName"}
Number iMultimedia_SmartTV_Channel "Kanalnummer" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:channel"}
String iMultimedia_SmartTV_Program_Name "Kanalname" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:channelName"}
String iMultimedia_SmartTV_Program_Title "Programmtitel" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:programTitle"}
String iMultimedia_SmartTV_Key_Code "Funktion aufrufen" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:keyCode"}
Switch iMultimedia_SmartTV_Power "Ein-/Ausschalten" (gMultimedia_SmartTV) {channel="samsungtv:tv:d3092a28_b6c8_4776_bc2b_44b5758f3e86:power"}
If I copy from PaperUI I get this channel:
This shouldn`t be the problem.
My sitemap look like this:
Frame label="Samsung TV" icon="video" {
Switch item=iMultimedia_SmartTV_Key_Code label="Kanal wechseln" icon="text" mappings=[KEY_CHUP="+", KEY_CHDOWN="-"]
Switch item=iMultimedia_SmartTV_Key_Code label="Lautstärke ändern" icon="text" mappings=[KEY_VOLUP="+", KEY_VOLDOWN="-"]
Switch item=iMultimedia_SmartTV_Key_Code label="Stumm" icon="text" mappings=[KEY_MUTE="ON", KEY_MUTE="OFF"]
Switch item=iMultimedia_SmartTV_Source_Name label="Quellenname" mappings=["TV"="TV","HDMI1/DVI"="HDMI1", "HDMI2"="HDMI2", "HDMI3"="HDMI3"] icon="none"
Switch item=iMultimedia_SmartTV_Power label="Ein-/Ausschalten"
What works is to change the volume and swtiching the power on and off.
What do I mean that it does not work? Well, he simply doesn’t change the source. The channel is apparently not supported for this. Unless I have overlooked the error, this might be possible via the keys. I connected the PS4 yesterday and it would be nice if I could not only switch on the TV but also switch to the correct HDMI. Or of course, in general, that I can switch there.
Thanks in advance and best regards
