fpracek
(Fausto)
April 23, 2018, 10:15am
1
my goal is to manage my Samsung air conditioner.
Thanks to the help of the forum, I wrote the following code and I can send the commands “power on” and “power off”. I also wrote a rule to activate a timer that checks the condition of the air conditioner in case it is controlled by the remote control. The latter, however, causing the switch to change if there is a difference between the detected state and that of the switch, creates a problem if I act on the switch and at the same time the timer intervenes. In practice, for example, if I press ON and the timer detects that the air conditioner is off, on its own initiative cancels my command and puts the switch back to the OFF state.
Do you have any ideas to help me?
Thank you
// *** SAMSUNG AC ITEMS ***
// Monolocale
Switch SamsungAC_Power_Monolocale "Monolocale" <heating>
Number SamsungAC_Temp_Monolocale "[Temperatura %d]"
Switch SamsungAC_Monolocale {channel="exec:command:samsungac_monolocale:run"}
String SamsungAC_Args_Monolocale {channel="exec:command:samsungac_monolocale:input"}
String SamsungAC_Out_Monolocale {channel="exec:command:samsungac_monolocale:output"}
// *** SAMSUNG AC RULES ***
// Monolocale
rule "Accensione/spegnimento Monolocale"
Item SamsungAC_Power_Monolocale changed
if(SamsungAC_Power_Monolocale.state == ON){
SamsungAC_Args_Monolocale.sendCommand("power on monolocale KBFz5iq6Wa 192.168.1.110")
val Number tempStatus = executeCommandLine("/etc/openhab2/samsungac/samsungac.sh temperature status monolocale KBFz5iq6Wa 192.168.1.110", 15000)
logDebug("SamsungAC","Lettura effettuata")
SamsungAC_Temp_Monolocale.postUpdate(tempStatus)
}else{
SamsungAC_Args_Monolocale.sendCommand("power off monolocale KBFz5iq6Wa 192.168.1.110")
SamsungAC_Temp_Monolocale.sendCommand(OFF)
while(SamsungAC_Monolocale.state != ON) Thread::sleep(100)
rule "Power Status check (5 sec) Monolocale"
Time cron "0/5 * * * * ?"
val String powerStatus = executeCommandLine("/etc/openhab2/samsungac/samsungac.sh power status monolocale KBFz5iq6Wa 192.168.1.110", 15000)
while(powerStatus != "\"On\"" && powerStatus != "\"Off\""){
Thread::sleep(500)
if(powerStatus == "\"On\"") {
if(SamsungAC_Power_Monolocale.state == OFF || SamsungAC_Power_Monolocale.state == NULL) {
SamsungAC_Power_Monolocale.postUpdate(ON)
}else{
if(SamsungAC_Power_Monolocale.state == ON || SamsungAC_Power_Monolocale.state == NULL) {
if(powerStatus == "\"Off\"") {
SamsungAC_Power_Monolocale.postUpdate(OFF)
vzorglub
(Vincent Regaud)
April 23, 2018, 10:52am
2
Could you edit your post with code fences, please
It will be much easier to read and understand
We all have to type this content over and over and over. Here is a posting we can all point to when the topic comes up.
Why use code fences?
Because rules, sitemap, logs, and configs are all but unreadable when code fences are not used.
When to use code fences?
Whenever one is posting any sort of code, config, log, and any text where line wrapping, indentation, and using an equal spaced font makes the text more legible.
How to use code fences?
Use 3 backticks (```)...
Or use <code>...
vzorglub
(Vincent Regaud)
April 23, 2018, 12:04pm
4
What is the content of: SamsungAC_Out_Monolocale? and how often do the binding pulls it?
Your while statements in the rules are holding the threads. Openhab has only 5 to play with.
I wonder if there is a better way to update your values directly from the binding without using the while statement.
What it the output of channel=“exec:command:samsungac_monolocale:output”?
fpracek
(Fausto)
April 23, 2018, 12:19pm
5
Thing exec:command:samsungac_monolocale [ command="/bin/sh /etc/openhab2/samsungac/samsungac.sh %2$s", interval=0, autorun=true ]
#!/bin/sh
arg="$1"
arg2="$2"
arg3="$3"
arg4="$4"
arg5="$5"
case "$arg" in
power|Power|POWER)
if [ "$arg2" = "on" ] || [ "$arg2" = "On" ] || [ "$arg2" = "ON" ] ; then
curl -k -H "Content-Type: application/json" -H "Authorization: Bearer "$arg4"" --cert /etc/openhab2/samsungac/samsungac_"$arg3".pem --insecure -X PUT -d '{"Operation" : {"power" : "On"}}' https://"$arg5":8888/devices/0
fi
if [ $arg2 = "off" ] || [ $arg2 = "Off" ] || [ $arg2 = "OFF" ] ; then
curl -k -H "Content-Type: application/json" -H "Authorization: Bearer "$arg4"" --cert /etc/openhab2/samsungac/samsungac_"$arg3".pem --insecure -X PUT -d '{"Operation" : {"power" : "Off"}}' https://"$arg5":8888/devices/0
fi
if [ "$arg2" = "status" ] || [ "$arg2" = "Status" ] || [ "$arg2" = "STATUS" ] ; then
power=`curl -s -k -H "Content-Type: application/json" -H "Authorization: Bearer "$arg4"" --cert /etc/openhab2/samsungac/samsungac_"$arg3".pem --insecure -X GET https://"$arg5":8888/devices|jq '.Devices[0].Operation.power'`
echo "$power"
fi
temperature|Temperature|TEMPERATURE)
if [ "$arg2" != "status" ] && [ "$arg2" != "Status" ] && [ "$arg2" != "STATUS" ] ; then
curl -k -H "Content-Type: application/json" -H "Authorization: Bearer "$arg4"" --cert /etc/openhab2/samsungac/samsungac_"$arg3".pem --insecure -X PUT -d '{"desired": ""$arg2"""}' https://"$arg5":8888/devices/0
else
temp=`curl -s -k -H "Content-Type: application/json" -H "Authorization: Bearer "$arg4"" --cert /etc/openhab2/samsungac/samsungac_"$arg3".pem --insecure -X GET https://"$arg5":8888/devices|jq '.Devices[0].Temperatures[0].current'`
echo $temp
fi
mode|Mode|MODE)
if [ $arg2 = "cool" ] || [ $arg2 = "Cool" ] || [ $arg2 = "COOL" ] ; then
curl -s -X PUT -d '{"modes": ["Cool"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "dry" ] || [ $arg2 = "Dry" ] || [ $arg2 = "DRY" ] ; then
curl -s -X PUT -d '{"modes": ["Dry"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "wind" ] || [ $arg2 = "Wind" ] || [ $arg2 = "WIND" ] ; then
curl -s -X PUT -d '{"modes": ["Wind"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "auto" ] || [ $arg2 = "Auto" ] || [ $arg2 = "AUTO" ] ; then
curl -s -X PUT -d '{"modes": ["Auto"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "heat" ] || [ $arg2 = "Heat" ] || [ $arg2 = "HEAT" ] ; then
curl -s -X PUT -d '{"modes": ["Heat"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
purify|Purify|Purify)
if [ $arg2 = "on" ] || [ $arg2 = "On" ] || [ $arg2 = "ON" ] ; then
curl -s -X PUT -d '{"options": ["Spi_On"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
curl -s -X PUT -d '{"options": ["Spi_Off"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
goodsleep|Goodsleep|GOODSLEEP)
if [ $arg2 = "1" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_2"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "2" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_4"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "3" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_6"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "4" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_8"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "5" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_10"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "6" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_12"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "7" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_14"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "8" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_16"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "9" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_18"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
if [ $arg2 = "10" ] ; then
curl -s -X PUT -d '{"options": ["Sleep_20"]}' -k -H "Content-Type: application/json" -H "Authorization: Bearer KBFz5iq6Wa" --cert /etc/openhab2/services/cert.pem --insecure https://192.168.1.110:8888/devices/0/mode
fi
esac
The binding is only an sh…
vzorglub
(Vincent Regaud)
April 23, 2018, 12:28pm
6
You could definne a binding for
instead of pulling it in an action and updating the value
Same for powerStatus = executeCommandLine("/etc/openhab2/samsungac/samsungac.sh power status monolocale KBFz5iq6Wa 192.168.1.110", 15000)
These values can be updated automatically by the binding and your rules will be much simpler without holding on the threads
vzorglub
(Vincent Regaud)
April 23, 2018, 12:35pm
8
I don’t have experience with the version2 of the exec binding so I couldn’t guide you any further down that path. But when you get your values updated directly from the binding at intervals that suit you (5s, 1min…) then come back, and we’ll work on the rules. I bet you that they’ll be far simpler…
Good luck
alexxio
(Alessio)
May 3, 2019, 4:52pm
9
Hi here’s my two cents hope it helps.
I think could be useful to change your rule and pay attention on the difference between sendCommand and postUpdate.
So in your first rule try to change the when clause from when “changed ” to “received command ” , this way the command will fire only when you manually trigger the switch, so when the “Power Status check ..” rule fires, the “postUpdate” will only change the value of the switch without triggering again the command.
