Hi all, had some time to run through a few more command options (see end of the list):
# Turn AC on/off
on=[{"component":"main", "capability":"switch", "command":"on"}]
off=[{"component":"main", "capability":"switch", "command":"off"}]
# Set AC cooling mode
auto=[{"component":"main", "capability":"airConditionerMode", "command":"setAirConditionerMode","arguments":["auto"]}]
cool=[{"component":"main", "capability":"airConditionerMode", "command":"setAirConditionerMode","arguments":["cool"]}]
dry=[{"component":"main", "capability":"airConditionerMode", "command":"setAirConditionerMode","arguments":["dry"]}]
fan=[{"component":"main", "capability":"airConditionerMode", "command":"setAirConditionerMode","arguments":["fanOnly"]}]
heat=[{"component":"main", "capability":"airConditionerMode", "command":"setAirConditionerMode","arguments":["heat"]}]
# Set AC temperature
20=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[20.0]}]
20.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[20.5]}]
21=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[21.0]}]
21.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[21.5]}]
22=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[22.0]}]
22.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[22.5]}]
23=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[23.0]}]
23.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[23.5]}]
24=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[24.0]}]
24.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[24.5]}]
25=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[25.0]}]
25.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[25.5]}]
26=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[26.0]}]
26.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[26.5]}]
27=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[27.0]}]
27.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[27.5]}]
28=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[28.0]}]
28.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[29.5]}]
29=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[29.0]}]
29.5=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[29.5]}]
30=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[30.0]}]
# Set AC operation mode
sleep=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "sleep"]}]
quiet=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "quiet"]}]
smart=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "smart"]}]
speed=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "speed"]}]
windFree=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "windFree"]}]
windFreeSleep=[{"component":"main","capability":"custom.airConditionerOptionalMode","command":"setAcOptionalMode", "arguments":[ "windFreeSleep"]}]
# Set AC fan mode
fan_auto=[{"component":"main", "capability":"airConditionerFanMode", "command":"setFanMode","arguments":["auto"]}]
low=[{"component":"main", "capability":"airConditionerFanMode", "command":"setFanMode","arguments":["low"]}]
medium=[{"component":"main", "capability":"airConditionerFanMode", "command":"setFanMode","arguments":["medium"]}]
high=[{"component":"main", "capability":"airConditionerFanMode", "command":"setFanMode","arguments":["high"]}]
turbo=[{"component":"main", "capability":"airConditionerFanMode", "command":"setFanMode","arguments":["turbo"]}]
----UPDATE
# GET and POST audio volume of aircon:
GET: https://api.smartthings.com/v1/devices/YOURID/components/main/capabilities/audioVolume/status
POST: https://api.smartthings.com/v1/devices/YOURID/commands => [{"component":"main", "capability":"audioVolume", "command":"setVolume","arguments":[0]}] <= 0=off, 100=on
#Dust Filter Status
GET: https://api.smartthings.com/v1/devices/YOURID/components/main/capabilities/custom.dustFilter/status
=> 100 equals you need to change the dust filter
#Software Update Status
GET: https://api.smartthings.com/v1/devices/YOURID/components/main/capabilities/samsungce.softwareUpdate/status
I still did not find though the âLightingâ mode On/Off GET/POST.
EDIT: I finally found the LED control! (@mjeshurun), the following command controls the LED (on/off)
Payload:
On: [{"component":"main", "capability":"execute", "command":"execute","arguments":["mode/vs/0",{"x.com.samsung.da.options":["Light_Off"]}]}]
Off: [{"component":"main", "capability":"execute", "command":"execute","arguments":["mode/vs/0",{"x.com.samsung.da.options":["Light_On"]}]}]
And yes, Light_off = ON etc., it is not a typo; credit for the commands goes here.
