Hi!
I declared a thing in paper ui. Samsung TV (samsungtv:tv:room:livingroom) and I get a online / offline if tv is on or off.
following configs:
things:
samsungtv:tv:room:livingroom [hostName=“192.168.1.15”, port=55000, refreshInterval=1000]
items:
Dimmer SamsungTV_Volume “Samsung TV - Lautstärke ändern” (TV) {channel=“samsungtv:tv:livingroom:volume”}
Switch SamsungTV_Mute “Samsung TV - Stumm” (TV) {channel=“samsungtv:tv:livingroom:mute”}
String SamsungTV_Source_Name “Samsung TV - Quellename” (TV) {channel=“samsungtv:tv:livingroom:sourceName”}
Number SamsungTV_Channel “Samsung TV - Kanalnummer” (TV) {channel=“samsungtv:tv:livingroom:channel”}
String SamsungTV_Program_Name “Samsung TV - Kanalname” (TV) {channel=“samsungtv:tv:livingroom:channelName”}
String SamsungTV_Program_Title “Samsung TV - Programmtitel” (TV) {channel=“samsungtv:tv:livingroom:programTitle”}
String SamsungTV_Key_Code “Samsung TV - Funktion aufrufen” (TV) {channel=“samsungtv:tv:livingroom:keyCode”}
Switch SamsungTV_Power “Samsung TV - Ausschalten” (TV) {channel=“samsungtv:tv:livingroom:power”}
sitemap:
Frame label=“Samsung TV” {
Group item=TV label=“TV Steuerung” {
Frame label=“Samsung TV Control” {
Switch item=SamsungTV_Key_Code label=“Kanal wechseln” icon=“text” mappings=[KEY_CHUP="+", KEY_CHDOWN="-"]
Switch item=SamsungTV_Key_Code label=“Lautstärke ändern” icon=“text” mappings=[KEY_VOLUP="+", KEY_VOLDOWN="-"]
Switch item=SamsungTV_Key_Code label=“Stumm” icon=“text” mappings=[KEY_MUTE=“ON”, KEY_MUTE=“OFF”]
Switch item=SamsungTV_Power label=“Ausschalten”
events.log:
2020-12-04 12:39:15.889 [hingStatusInfoChangedEvent] - ‘samsungtv:tv:room:livingroom’ changed from INITIALIZING to OFFLINE
2020-12-04 12:39:15.897 [hingStatusInfoChangedEvent] - ‘samsungtv:tv:room:livingroom’ changed from OFFLINE to ONLINE
tried to click on sitemap:
2020-12-04 12:43:37.460 [ome.event.ItemCommandEvent] - Item ‘SamsungTV_Key_Code’ received command KEY_VOLUP
2020-12-04 12:43:37.466 [nt.ItemStatePredictedEvent] - SamsungTV_Key_Code predicted to become NULL
2020-12-04 12:43:42.659 [ome.event.ItemCommandEvent] - Item ‘SamsungTV_Key_Code’ received command KEY_VOLUP
2020-12-04 12:43:42.664 [nt.ItemStatePredictedEvent] - SamsungTV_Key_Code predicted to become NULL
2020-12-04 12:43:43.182 [ome.event.ItemCommandEvent] - Item ‘SamsungTV_Key_Code’ received command KEY_VOLUP
2020-12-04 12:43:43.188 [nt.ItemStatePredictedEvent] - SamsungTV_Key_Code predicted to become NULL
nothing happens… Do I have to pair the device ? or is it already ? nothing works at the moment to control…
