Samsung TV Binding Not working after upgrade to openHAB 4
Hi, After upgrade to openHAB 4 my Samsung UE40KU7000 connection is not ok.
Port:8001
Status:
UNKNOWN
2023-11-19 04:03:17.391 [WARN ] [tv.internal.handler.SamsungTvHandler] - 192.168.1.30: Not creating remote controller service: config is websocket - ignoring UPNP service
2023-11-19 04:03:17.393 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler@37fc7341': org/openhab/core/service/AbstractWatchService
java.lang.NoClassDefFoundError: org/openhab/core/service/AbstractWatchService
	at org.openhab.binding.samsungtv.internal.protocol.RemoteControllerWebSocket.<init>(RemoteControllerWebSocket.java:178) ~[?:?]
	at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.<init>(RemoteControllerService.java:95) ~[?:?]
	at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.createNewService(SamsungTvHandler.java:584) ~[?:?]
	at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.createService(SamsungTvHandler.java:550) ~[?:?]
	at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.checkAndCreateServices(SamsungTvHandler.java:515) ~[?:?]
	at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.initialize(SamsungTvHandler.java:371) ~[?:?]
	at org.openhab.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:155) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) ~[?:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:840) ~[?:?]
Caused by: java.lang.ClassNotFoundException: org.openhab.core.service.AbstractWatchService cannot be found by org.openhab.binding.samsungtv_3.3.0.202204291417
Any thoughts or suggestions on this?
Could it be that you use a binding that is not compatible with OH 4 ?
Sorry had both “Samsung TV” and “Samsung TV Beta” enabled.
