Hi all,
a few days ago I could turn off my Samsung TV using the Samsung TV Binding in openhab. No the TV is no responding on my requests anymore. Below you can see my log file, I hope you guys have a clue what is going on there:
2018-05-24 18:41:06.044 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.samsungtv.handler.SamsungTvHandler@97ef2b': Command 'OFF' not supported
java.lang.NumberFormatException: Command 'OFF' not supported
at org.openhab.binding.samsungtv.internal.service.MediaRendererService.setVolume(MediaRendererService.java:251) [240:org.openhab.binding.samsungtv:2.2.0]
at org.openhab.binding.samsungtv.internal.service.MediaRendererService.handleCommand(MediaRendererService.java:153) [240:org.openhab.binding.samsungtv:2.2.0]
at org.openhab.binding.samsungtv.handler.SamsungTvHandler.handleCommand(SamsungTvHandler.java:114) [240:org.openhab.binding.samsungtv:2.2.0]
at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [109:org.eclipse.smarthome.core:0.10.0.b1]
at com.sun.proxy.$Proxy165.handleCommand(Unknown Source) [240:org.openhab.binding.samsungtv:2.2.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:72) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
2018-05-24 18:41:45.860 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:power' not supported
2018-05-24 18:41:46.793 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:power' not supported
2018-05-24 18:41:47.345 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:power' not supported
2018-05-24 18:41:49.479 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:mute' not supported
2018-05-24 18:41:50.306 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:mute' not supported
2018-05-24 18:41:50.859 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:mute' not supported
2018-05-24 19:56:02.526 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:0f7f4900_0004_1000_92dd_5056bf182f1b' to inbox.
2018-05-24 20:00:27.034 [INFO ] [g.samsungtv.handler.SamsungTvHandler] - Error was reported: Could not send command to device on 192.168.1.33:55000
org.openhab.binding.samsungtv.internal.protocol.RemoteControllerException: Unknown response received for access query
at org.openhab.binding.samsungtv.internal.protocol.RemoteController.openConnection(RemoteController.java:165) [240:org.openhab.binding.samsungtv:2.2.0]
at org.openhab.binding.samsungtv.internal.protocol.RemoteController.sendKey(RemoteController.java:204) [240:org.openhab.binding.samsungtv:2.2.0]
at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.sendKeyCode(RemoteControllerService.java:189) [240:org.openhab.binding.samsungtv:2.2.0]
at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.handleCommand(RemoteControllerService.java:135) [240:org.openhab.binding.samsungtv:2.2.0]
2018-05-24 20:00:27.188 [WARN ] [g.samsungtv.handler.SamsungTvHandler] - Channel 'samsungtv:tv:0f7f4901_0004_1000_9703_f47b5e62f4a2:volume' not supported
this is only a snippet, I cannot post the whole log because post are limited to 3200 signs.
edit: I uninstalled and reisntalled the binding, it´s working now but I am quiet sure it will not last long…
