Hello everyone. I’m setting up my Samsung TV with OpenHab and I have managed to get on/off, mute and volume to work (the basics).
Now I want to implement these items in my Apple application. I have managed to get power on/off to work successfully, but I can`t get volume change or mute status to work.
Group gTelevision "Living room TV" <screen> { homekit="Television" }
Switch TV_Power "Power" (gTelevision) { homekit="Television.Active", channel="samsungtv:tv:livingroom:power" }
Dimmer TV_Volume "Volume" <soundvolume> (gTelevision) { channel="samsungtv:tv:livingroom:volume" }
Switch TV_Mute "Mute" <soundvolume_mute> (gTelevision) { channel="samsungtv:tv:livingroom:mute" }
String TV_SourceApp "Source App" (gTelevision) { homekit="Television.ConfiguredName", channel="samsungtv:tv:livingroom:sourceApp" }
Group gTelevisionSpeaker "Speaker" (gTelevision) { homekit="TelevisionSpeaker" }
Switch Television_Mute "Mute" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Mute", channel="samsungtv:tv:livingroom:mute" }
Any idea if this is actually available? On the other hand, I also wanted to implement the Input but I don’t know how to handle that behavior either (all based on this image where you can see that you can change the input from Home).
Thanks.
