WHen i rerquest to load netflix (or any other app) an error is thrown
2021-10-26 09:10:00.282 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'TV_SourceApp' received command plex
2021-10-26 09:10:00.300 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'TV_SourceApp' predicted to become plex
2021-10-26 09:10:00.310 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TV_SourceApp' changed from netflix to plex
==> /opt/openhab/userdata/logs/openhab.log <==
2021-10-26 09:10:00.308 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler@18e279f': null
at org.openhab.binding.samsungtv.internal.protocol.RemoteControllerWebSocket.sendSourceApp(RemoteControllerWebSocket.java:338) ~[?:?]
at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.handleCommand(RemoteControllerService.java:280) ~[?:?]
at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.handleCommand(SamsungTvHandler.java:115) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy947.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
here is my setup…
Group gLivingRoomTV "Living room TV" <television> (GF_Living)
ga="TV"
availableChannels="101=101=BBC,102=Channel2=BBC Two,103=Channel3=ITV",
availableApplications="youtube=YouTube:YouTube,netflix=Netflix:Netflix,plex=Plex=Plex"
Switch TV_Power "Power" (gLivingRoomTV) { ga="tvPower", channel="samsungtv:tv:livingroom:power" }
Dimmer TV_Volume "Volume" <soundvolume> (gLivingRoomTV) { ga="tvVolume", channel="samsungtv:tv:livingroom:volume" }
Switch TV_Mute "Mute" <soundvolume_mute> (gLivingRoomTV) { ga="tvMute", channel="samsungtv:tv:livingroom:mute" }
Number TV_SourceId "Source Id" (gLivingRoomTV) { channel="samsungtv:tv:livingroom:sourceId" }
String TV_SourceName "Source Name" (gLivingRoomTV) { ga="tvInput", channel="samsungtv:tv:livingroom:sourceName" }
String TV_SourceApp "Source App" (gLivingRoomTV) { ga="tvApplication", channel="samsungtv:tv:livingroom:sourceApp" }
String TV_ProgramTitle "Program Title" (gLivingRoomTV) { channel="samsungtv:tv:livingroom:programTitle" }
String TV_ChannelName "Channel Name" (gLivingRoomTV) { channel="samsungtv:tv:livingroom:channelName"}
Number TV_ChannelNumber "Channel Number" (gLivingRoomTV) { ga="tvChannel", channel="samsungtv:tv:livingroom:channel"}
String TV_KeyCode "Key Code" (gLivingRoomTV) { channel="samsungtv:tv:livingroom:keyCode" }
Switch TV_ArtMode "Art Mode" (gLivingRoomTV) { channel="samsungtv:tv:livingroom:artMode" }
Can anyone help?
