Hi I’m currently on OH version 2.5.8 and have a QN65Q90. in previous OH versions (around 2.5.5/2.5.6) this binding used to work flawlessly. In the most recent version, however, I’ve encountered issues with turning the tv off. Whenever I use OH to send a power off command the tv does turn off but then it turns right back on. The logs during this are attached below. I’ve noticed that the websocketclient failure message pop up when I turn the tv off via the remote as well.
> 2020-09-01 11:00:15.961 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.nio.channels.ClosedSelectorException
> 2020-09-01 11:00:15.961 [WARN ] [l.protocol.RemoteControllerWebSocket] - WebSocketClient failure: java.lang.InterruptedException
> 2020-09-01 11:00:15.975 [WARN ] [ngtv.internal.protocol.WebSocketBase] - WebSocketRemote sending command while socket not connected: {"method":"ms.remote.control","params":{"Cmd":"Click","DataOfCmd":"KEY_POWER","Option":"false","TypeOfRemote":"SendRemoteKey"}}
> 2020-09-01 11:00:15.975 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler@5c89a562': null
> java.lang.NullPointerException: null
> at org.openhab.binding.samsungtv.internal.protocol.WebSocketBase.sendCommand(WebSocketBase.java:119) ~[?:?]
> at org.openhab.binding.samsungtv.internal.protocol.WebSocketRemote.sendKeyData(WebSocketRemote.java:224) ~[?:?]
> at org.openhab.binding.samsungtv.internal.protocol.RemoteControllerWebSocket.sendKeyData(RemoteControllerWebSocket.java:331) ~[?:?]
> at org.openhab.binding.samsungtv.internal.protocol.RemoteControllerWebSocket.sendKey(RemoteControllerWebSocket.java:265) ~[?:?]
> at org.openhab.binding.samsungtv.internal.protocol.RemoteControllerWebSocket.sendKey(RemoteControllerWebSocket.java:250) ~[?:?]
> at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.sendKeyCode(RemoteControllerService.java:413) ~[?:?]
> at org.openhab.binding.samsungtv.internal.service.RemoteControllerService.handleCommand(RemoteControllerService.java:290) ~[?:?]
> at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.handleCommand(SamsungTvHandler.java:122) ~[?:?]
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_265]
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_265]
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_265]
> at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_265]
> at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
> at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
> at com.sun.proxy.$Proxy257.handleCommand(Unknown Source) [?:?]
> at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
> at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
> at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
> at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_265]
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
> at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
