I don’t know how samsung range was in 2010 sorry, but what’s the actual model number? If it ends with 5xxx then it’s series 5 and it will work. If it ends in 6xxx or 7xxx then it won’t.
I’d done a forum search a while back about it and there was comment about series 5 being the newest series supported. I couldn’t get my series 7 working so never looked at it again.
If the OH1 binding worked, then it’ll need more investigation and my series 7 TV doesn’t work so i’m not much more help sorry.
Hi
The documentation is wrong. “keycode” should be “keyCode”, that’s why I was getting the channel not supported error. The same happens to sourceName, programTitle, channelName… (composed named) channels.
It seems that the C (2010) model only supports the volume, mute, brightness, contrast, sharpness, colorTemperature, power and keyCode channels.
I also tried it on a E (2012) model and everything seems to work. @pauli_anttila, please, update de documentation.
Thanks.
