Samsung TV: Setting volume stops working after a while
Hi all,
Problem is solved by installing the snapshot verison of the samsung tv binding by Nicholas_Waterton.
Important: For installing bindings manually, first the current active / bundled version needs to be uninstalled! Afterwards place the manually downloaded binding in the addons folder. If you do not uninstall the bundled binding, the one in the addons folder will be (silently?) ignored.
Regards,
Chris
