Hi all,
i’m trying to connect my Samsung TV to openHAB. I have added binding and added a new samsung tv thing manually.
After saving item i have received a message on to in order to authorize openHAB to access it. But after this operation i have an error on openHAB and is not able to communicate with TV.
Looking into TV settings i have noticed that into “AllShare Settings” the previous authorization was for “openHAB” but for the wrong IP address of server.
Here i have the IP of the bridge of docker instance and not the IP of the server network interface.
There is a way to override it in configuration so openHAB “publish” the correct IP or i have to change docket network configuration?
Thank you.
