Linux Ubuntu 18.04
openHAB 2.4
samsungtv binding 2.5-SNAPSHOT
I can’t make it work with UN55MU6300 thing.
The state is Unknown.
I see communications between openHAB and a TV:
tcpdump -vv -X src 10.10.5.15 and dst 10.10.5.118 and port 8001
10.10.5.15.40586 > 10.10.5.118.8001: Flags [P.], cksum 0xaffe (correct), seq 14:21, ack 7, win 254, options [nop,nop,TS val 717232745 ecr 75735519], length 7
0x0000: 4500 003b ba0e 0000 4006 a216 0a0a 050f E..;....@.......
0x0010: 0a0a 0576 9e8a 1f41 9fc2 54c6 31c4 57bf ...v...A..T.1.W.
0x0020: 8018 00fe affe 0000 0101 080a 2ac0 1a69 ............*..i
0x0030: 0483 a1df 8a81 03fc ee37 03
tcpdump -vv -X dst 10.10.5.15 and src 10.10.5.118 and port 8001
10:44:12.953899 IP (tos 0x0, ttl 64, id 58495, offset 0, flags [DF], proto TCP (6), length 52)
10.10.5.118.8001 > 10.10.5.15.40584: Flags [.], cksum 0x6505 (correct), seq 3, ack 8, win 235, options [nop,nop,TS val 75756525 ecr 717316769], length 0
0x0000: 4500 0034 e47f 4000 4006 37ac 0a0a 0576 E..4..@.@.7....v
0x0010: 0a0a 050f 1f41 9e88 ca26 1870 4116 8aea .....A...&.pA...
0x0020: 8010 00eb 6505 0000 0101 080a 0483 f3ed ....e...........
0x0030: 2ac1 62a1 *.b.
I even disabled tcp offloading on the server nic to fix tcp/udp checksum errors :
ethtool -K enp5s0 tx off rx off
openHAB and UN55MU6300 do not understand each other?
At least as of today, UN55MU6300 is not listed as a tested TV on Samsung TV - Bindings | openHAB
This might be helpful:
| device | |
| FrameTVSupport | “false” |
| GamePadSupport | “true” |
| ImeSyncedSupport | “true” |
| OS | “Tizen” |
| TokenAuthSupport | “true” |
| VoiceSupport | “true” |
| countryCode | “US” |
| description | “Samsung DTV RCR” |
| developerIP | “0.0.0.0” |
| developerMode | “0” |
| duid | “uuid:b53757e5-3bc1-42e5-b115-42c02f9093b5” |
| firmwareVersion | “Unknown” |
| ip | “10.10.5.118” |
| model | “17_KANTM_UHD_BASIC” |
| modelName | “UN55MU6300” |
| name | “[TV] Samsung 6 Series (55)” |
| networkType | “wireless” |
| resolution | “3840x2160” |
| smartHubAgreement | “true” |
| ssid | “10:da:43:8f:a3:25” |
| type | “Samsung SmartTV” |
| udn | “uuid:b53757e5-3bc1-42e5-b115-42c02f9093b5” |
| wifiMac | “F8:3F:51:7C:92:94” |
| isSupport | “{"DMP_DRM_PLAYREADY":"false","DMP_DRM_WIDEVINE":"false","DMP_available":"true","EDEN_available":"true","FrameTVSupport":"false","ImeSyncedSupport":"true","TokenAuthSupport":"true","remote_available":"true","remote_fourDirections":"true","remote_touchPad":"true","remote_voiceControl":"true"}\n” |
| remote | “1.0” |
| uri | “http://10.10.5.118:8001/api/v2/” |
| version | “2.0.25” |
UPDATE:
Turning on works (not always) but nothing else.
I have just tested an Android Samsung Smart TV WiFi Remote. It looks like it starts its communications on 8001 and then switches to 8002. It requires pairing with TV. I do not know it might be a websocket token must be generated. How?
