edit: Issue was present on 1431, was fixed on 1432, exists on 1440, 1441, present also on latest 1442, fixed on 1443, re-appeared on 1447, fixed on 1448, re-appeared on 1450, fixed on 1452, re-appeared on 1454
Binding in question: binding-samsungtv - 2.4.0.SNAPSHOT
just upgraded from openHAB 2.4.0 Snapshot Build #1430 to #1431 and I see the following on startup:
2018-11-18 19:04:36.220 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201811181035 (237)[org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory] : Cannot register component
org.osgi.service.component.ComponentException: The component name 'org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory' has already been registered by Bundle 237 (org.openhab.binding.samsungtv) as Component of Class org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory
at org.apache.felix.scr.impl.ComponentRegistry.checkComponentName(ComponentRegistry.java:235) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.loadDescriptor(BundleComponentActivator.java:443) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialize(BundleComponentActivator.java:315) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:270) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:379) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-11-18 19:04:36.248 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201811181035 (237)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(247)] : activate method [activate] not found; Component will fail
2018-11-18 19:04:36.265 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1801) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
Caused by: java.lang.NullPointerException
at org.apache.felix.scr.impl.manager.AbstractComponentManager.setServiceProperties(AbstractComponentManager.java:1411) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:362) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
... 64 more
2018-11-18 19:04:36.331 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a service object that is not an instance of the service class org.eclipse.smarthome.config.discovery.upnp.UpnpDiscoveryParticipant
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:243) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
Just checking if anyone else is seeing the same before I open up an github issue
Tried restart, clean cache… everything that I know
upgraded to OH 2.4.0.S1442 … issue came back… it’s a zombie !
2018-11-24 12:30:16.978 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201811232341 (238)[org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory] : Cannot register component
org.osgi.service.component.ComponentException: The component name 'org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory' has already been registered by Bundle 238 (org.openhab.binding.samsungtv) as Component of Class org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory
2018-11-24 12:30:17.022 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201811232341 (238)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(242)] : activate method [activate] not found; Component will fail
2018-11-24 12:30:17.072 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
... 64 more
2018-11-24 12:30:17.149 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
2018-12-01 08:44:49.916 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812010216 (237)[org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory] : Cannot register component
2018-12-01 08:44:49.930 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812010216 (237)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(243)] : activate method [activate] not found; Component will fail
2018-12-01 08:44:49.954 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
... 55 more
2018-12-01 08:44:50.071 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
ok… I am about to throw my Samsung TV to the trashcan just to see if this goes away
It may very well be due to my TV device… It is old and has started to have some problems lately (it reboots by itself)… edit: TV is unplugged and still getting the same.
It re-appeared on openHAB 2.4.0 Snapshot Build #1450
No-one else is seeing the same?
2018-12-05 07:04:03.763 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812050105 (237)[org.openhab.binding.samsungtv.internal.SamsungTvHandlerFactory] : Cannot register component
2018-12-05 07:04:03.806 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812050105 (237)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(243)] : activate method [activate] not found; Component will fail
2018-12-05 07:04:03.843 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
... 64 more
2018-12-05 07:04:03.947 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
Yes I am too. The binding still works though…
I think there was an update of the binding recently to add more recent TVs. but I may be wrong.
You are the boss when it comes to checking gitHub. Can you confirm?
But I cannot explain why this issue appears and disappears from one Snapshot to the other (since there have been no further updates to the SamsungTV Binding since this PR)
issue disappeared on S1452 (if I remember well),
reappeared on S1454
2018-12-08 11:08:19.845 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812080055 (238)[org.openhab.binding.samsungtv.interna
2018-12-08 11:08:19.863 [ERROR] [org.openhab.binding.samsungtv ] - bundle org.openhab.binding.samsungtv:2.4.0.201812080055 (238)[org.openhab.binding.samsungtv.interna
2018-12-08 11:08:19.865 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
... 64 more
2018-12-08 11:08:20.009 [ERROR] [org.openhab.binding.samsungtv ] - FrameworkEvent ERROR - org.openhab.binding.samsungtv
