The Satel Binding documentation describes a lot more channels for partitions than I can see in PaperUI. For example armed_mode_1, armed_mode_2 etc. Why are these channels not available?
Using the Rest API I tried to manually link a switch item to channel armed_mode_1. When I use this switch, the partition gets armed, so it looks like the channel is working.
However, if I arm this partition in mode 1, the switch is not set to ON. Only the armed channel is enabled.
Any idea?
