I have a question regarding channel violated_zones for partiotion. Should it be ON when any of zones in partition is violated enen if partiotion is not in Armed state ?
Hi Andy.
My understanding is, that your assumption is correct, but I haven’t tested it ever. I am not using this channel in my system, but it should be easy to test.
The documentation is not helpful in this matter (not only this), there is only such mention about this command:
”0x25 partitions with violated zones 0x25 + 4 bytes”
However similar command for zones works this way for zone channel “violation”:
”0x00 zones violation 0x00 + 16/32 bytes”
It is ON when violated even on unarmed system.
For zone channel violation is working, also for partition for example “really armed” or “alarm” are working. Also I can see on phone application signaling violation of partition, but do not see any change in corresponding item in openhab in logs.
Maybe I can provide for you some trace logs ?
Yes, if you have logs, that would be helpful.
I attached some log. The violation of zone (SatelCzujkaPietroSypialnia_Violation) was between 07:16:00 and 07:17:00 and at that time in the log there is now sign of Partition Violation.
events.violation.log (1.7 KB)
openhab.log (747.1 KB)
Apparently something is wrong on the system side:
NewStatesEvent: changed = [00,01,02,04,05,06,08,09,0B,0C,0D,0E,0F,10,11,12,14,16,18,19,1B,1C,1D,1E,1F,20,21,22,23,24,26,27,28,29,2A,2B,2C,2D,2E,2F]
00 state is changed, therefore you got “zone violation” events, but there is no change in 25 state, which is “partitions with violated zones”.
Could you please send me your system details (mainboard, version, ethm version)? I will contact support regarding this issue.
Hi, info send.
