Say command and number item
Hi
I need to say command in a rule to tell my the temperature outside, but my sensor sometimes add a large number to the item.
Sometimes the number is -2.80000003, and when I use the say command it tells my something like 2.8 million degrees.
Is it possible to tell it to only add 0.1 numbers, so it only tells me -2,8
say("The temperature is " + Temp_ude.state.toString + "Grader","voicerss:daDK","sonos:PLAY1:RINCON_949F3E72CEE801400")
Try this:
say("The temperature is ", String::format("Temp %.1f °C", Temp_ude.state) + "Grader","voicerss:daDK","sonos:PLAY1:RINCON_949F3E72CEE801400")
I get this error, when trying to run the rule
2018-11-26 21:00:49.908 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Godmorgen hilsen': f != org.eclipse.smarthome.core.library.types.DecimalType
What error were you getting before?
I added .toString below.
say("The temperature is ", String::format("Temp %.1f °C", Temp_ude.state.toString) + "Grader","voicerss:daDK","sonos:PLAY1:RINCON_949F3E72CEE801400")
I get this error now
2018-11-26 21:31:04.740 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Godmorgen hilsen': f != java.lang.String
with this command, it works
say("Godmorgen alle sammen,.....  temperaturen udenfor er lige nu" + Temp_ude.state + "Grader","voicerss:daDK","sonos:PLAY1:RINCON_949F3E72CEE801400")
Awesome!
@Dim will be glad to hear the news.
I knew we could figure it out.:joy: Now I gotta read more on using say.:smile:
Sorry the 2. command works with no errors in the log, but it still tells me the temperature with all the zeros.
I will send you in the deep waters, but you will be able to see several examples of what you want to do:
https://github.com/yfaway/openhab-rules/blob/master/automation/jsr223/music-and-announcement.py
This one uses another scripting engine (JSR223) and you don’t have to use exactly the same stuff.
You can see several formatting examples in the code.
Why don’t you compose the string to be said in an extra variable an let the TTS say this variable?
I am not sure what you saying, can you show me an example?
Something like this:
rule “SaySomething”
…//Your Trigger
var string TextString
TextString= "The temperature is "+ String::format(“Temp %.1f °C” ,Temp_ude.state.toString) + “Grader”
LogInfo (“SaySomething”, “TextString. {}”, TextString)
say(TextString,“voicerss:daDK”,“sonos:PLAY1:RINCON_949F3E72CEE801400”)
Hi
I get an error running the rule, I did try to only run the the say command, and there is also an error
rule "Godmorgen hilsen"
        Item Panel_Lock changed
 	say("The temperature is "+ String::format("Temp %.1f °C" ,Temp_ude.state.toString) + "Grader","voicerss:daDK","sonos:PLAY1:RINCON_B8E937B7EB3601400")
I get this error
2018-11-28 15:37:51.092 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Godmorgen hilsen': f != java.lang.String
I’m at my system now and can test!
This did work for me:
rule "SayTemperature"
        Item TestSomething changed
	  var String AudioSink
    AudioSink= "sonos:PLAY1:RINCON_949F3E7D2EF401400"
 	  var String SayText
    SayText="Die Temperatur ist "+  CPUTemperature.state + " Grad Celcius"
    SayText=SayText.replace(".",",")
    logInfo("SayTemperature", "SayText: {}",SayText)
    say(SayText,"voicerss:deDE",AudioSink)
I needed the .replace bercause the numbers are stored “english” i.e. the decimal seperator is a point, in order to get the correct german sentence I replaced the “.” with a “,”! Otherwise the said text would have been your observed large number!
Note that only the stored number is coming from the item, hence no need for the “°C” and the preceeding “Temp”.
My CPUTemprature has a value of “54.2000000000000028421709430404007434844970703125” according a REST API call, however the SayText is " Die Temperatur ist 54,2 Grad Celcius"!!
Sorry for earlier posting with a not working example. I’m really missing the VPN to my raspi, no way to look at my rules when I’m not at home :disappointed:
Hi
I did try to test your code, it tells me all the numbers in the say and the loginfo
Here is the modified code
    AudioSink= "sonos:PLAY1:RINCON_949F3E72CEE801400"
 	  var String SayText
    SayText="Temperaturen er "+  Temp_ude.state + " Grader Celcius"
   say(SayText,voicerss:daDK,AudioSink)
2018-11-28 21:02:35.254 [INFO ] [marthome.model.script.SayTemperature] - SayText: Temperaturen er 3,2222222 Grader Celcius
How does your item looks like, my is like this;
Number 		Temp_ude			"Temperatur [%.1f °C]"		<temperature>		(Temperatur,Vejr)
Hi
Now it works, this is the right format for the command:
Temp_ude.state.format("%.1f")
Actually my item has no formatting in the definition, I have that in the sitemap file.
I can’t say why it works differently.
Thanks for your help, it really helped me with this code, because i had the same issue.
If your problem is solved, please mark the post that solved it with “solution” checkmark
You can do all of the changes (replace as well as the format) in one go without variable..
This is my rule file, working fine:
rule    "Voice Testing Rule"
		Item    Voice_Robot     changed from OFF to ON
 say("Temperaturen i kontoret er" + kontor_Temperature.state.format("%.1f").replace(".",",") + "grader!")
