- Platform information:
- Hardware: x64/8 GB/512 GB
- OS: Ubuntu 22.04.5 LTS
- Java Runtime Environment: Debian 17.0.12
- openHAB version: 4.2.1 (official Docker version)
- Issue of the topic: How to chain transformations in .things; especially SCALE transformation
So I have this thing (.things) configuration for my battery operated Shelly devices:
Thing mqtt:topic:shellyhtg3-543204563724 "shellyhtg3-543204563724" (mqtt:broker:mosquitto) {
Channels:
Type number : wifi_rssid "RSSID" [ stateTopic="shellyhtg3-543204563724/status/wifi", transformationPattern="JSONPATH:$.rssi"]
This perfectly delivers the rssi of the wifi signal, e.g. â-67â.
The OH Shelly-binding however gives positive integer values like e.g. â2â for wireless signal strength which is nicely rendered in the UI when using the <qualityofservice> icon.
So, I stumbled upon the SCALE transformation which looked that it can transform the signal strength dB-values to those numbers known from the Shelly binding.
I now have a db.scale file:
]-55..]=4
]-65..-55]=3
]-75..-65]=2
[..-75]=1
I got it to transform my mqtt-thing values in the .items config:
Number HT302_WifiSignalMQTT "SignalstÀrke" <qualityofservice> (EG, GR_Kitchen) {channel="mqtt:topic:shellyhtg3-543204563724:wifi_rssid" [profile="transform:SCALE", function="db.scale"]}
However, I thought that using the â© (intersection) symbol, I could somehow chain the JSONPATH and SCALE transformation already in the thing instead of the display state in the item as I am doing now.
Unfortunately, the following doesnât work:
Type number : wifi_rssid "RSSID" [ stateTopic="shellyhtg3-543204563724/status/wifi", transformationPattern="JSONPATH:$.rssâ©SCALE(db.scale):%s"]
The documentation on the MQTT things shows a similar combination of transformation in the last example (above the âLimitationsâ section), but I canât figure out, how the syntax for SCALE would be or if SCALE is supported in the thing transformation at all.
Any help is appreciated.
Best regards
Marco
