Scale transformations not working at all?
Scale with ranges not working at all?
I am trying to get scale transformations to work. I have several use cases but one specific is for my personal weather station. This return a direction in degrees that I want to convert to a string like “N”, “E”, “S” or W".
compass.scale
[0..44]=N
[45..134]=E
[135..224]=S
[225..304]=W
[305..360]=N
I keep getting errors like these
2017-02-18 08:41:00.202 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '315' with the file 'compas
s.scale' : Target value not found in map for '315'
To me it looks like as if the scale is not working at all.
I face the same problem. Works well with single values (i.e 3=Full) but not with ranges (i.e. [2..3]=Full)
Did you manage to find a solution using SCALE/MAP ?
Documentation here seems inaccurate : http://docs.openhab.org/addons/transformations/scale/readme.html#example
Did you try it in the OH1 syntax [0,89] for 0 to 89?
It worked for me after restarting openhab…
