My Openhab is running in docker container. I installed sonos binding through paperui extensions tab. binding installed properly and also listed in paper ui . But when I am clicking on Inbox->Sonos Binding it only giving me Add Manually option to add sonos ,there is no auto searching for sonos device.
Please tell me if I am missing something in configurations.
When running in Docker OH has limited permissions on certain network capabilities. This could be causing you problems. You can try to run the container as the root user and see if that helps. I’m assuming you are using --net=host. You can also try looking at the Docker thread on this forum and look into the macvlan approach. I’ve had no chance to look into either myself yet.
