Hi ,
I apologise if this is not relevant as it is relating to HestiaPi which is an openhab based themostat .
I need someone who is wiser than myself to check my scheduling rule and advise me on corrections and if it would work at all.
these are my item, sitemap and rules files but edited to some degree to only show relevant entries
default items
Switch HeatingPin23 "Heating" { gpio="pin:23", mqtt=">[mosquitto:hestiapidown/local/heatingstate:command:ON:1],>[mosquitto:hestiapidown/local/heatingstate:command:OFF:0],<[mosquitto:hestiapidown/local/heatingstate:state:MAP(binary.map)]" }
String MyTemp "Temperature" <temperature> { channel="exec:command:gettemp:output" }
Number MyTempProxy "Temperature [%.1f °C]" <temperature> { mqtt=">[mosquitto:hestiapidown/local/temperature:state:*:default]" }
String MyHumi "Humidity" <humidity> { channel="exec:command:gethumi:output" }
Number MyHumiProxy "Humidity [%.0f %%]" <humidity> { mqtt=">[mosquitto:hestiapidown/local/humidity:state:*:default]" }
String MyPressure "Pressure" <pressure> { channel="exec:command:getpress:output" }
Number MyPressureProxy "Pressure [%.2f hPa]" { mqtt=">[mosquitto:hestiapidown/local/pressure:state:*:default]" }
Number TempSetpoint "Temperature Setpoint[%.1f °C]" { mqtt=">[mosquitto:hestiapidown/local/tempsetpoint:state:*:default],<[mosquitto:hestiapidown/local/settempsetpoint:command:default]"}
Number TempSetpointChart "Heating Setpoint" (charts)
Switch IncTargetTemp "IncTargetTemp"
Switch DecTargetTemp "DecTargetTemp"
Number TargetTemp
Number PreviousTempReading "Temperature" <temperature> (charts)
Number HeatingBoostTime "Heating Boost Time [%.0f min]"
Switch HeatingBoostTimeDec "HeatingBoostTimeDec"
Switch HeatingBoostTimeInc "HeatingBoostTimeInc"
String HeatingMode "Heating Mode"
Switch MainSwitch "MainSwitch"
String HeatingTimer "Heating Timer"
default rules
rule "Initialisation"
System started
MainSwitch.sendCommand("OFF")
HeatingMode.sendCommand("OFF")
HotWaterMode.sendCommand("OFF")
HumiMode.sendCommand("OFF")
HeatingTimer.sendCommand("OFF")
/**CELSIUS*/ if(TempSetpoint.state == NULL) postUpdate(TempSetpoint, 18)
/**CELSIUS*/ if(TempSetpoint.state > 40) postUpdate(TempSetpoint, 18)
//FAHRENHEIT if(TempSetpoint.state == NULL) postUpdate(TempSetpoint, 70)
//FAHRENHEIT if(TempSetpoint.state < 32) postUpdate(TempSetpoint, 70)
if(HumiSetpoint.state == NULL) postUpdate(HumiSetpoint, 50)
if(HeatingBoostTime.state == NULL) postUpdate(HeatingBoostTime, 10)
if(HotWaterBoostTime.state == NULL) postUpdate(HotWaterBoostTime, 10)
if(HumiBoostTime.state == NULL) postUpdate(HumiBoostTime, 10)
TempSetpointChart.sendCommand(0);
HumiSetpointChart.sendCommand(0);
PreviousTempReading.sendCommand(0);
PreviousHumiReading.sendCommand(0);
chart_period.sendCommand(0);
rule "checkcurrtemp"
Item TempSetpoint changed or
Item PreviousTempReading changed
if (MyTempProxy.state > TempSetpoint.state){
HeatingPin23.sendCommand(OFF)
} else if ((MyTempProxy.state < TempSetpoint.state) &&
((HeatingMode.state=="ON") || (HeatingMode.state=="Boost") || (HeatingTimer.state=="ON"))) {
HeatingPin23.sendCommand(ON)
TempSetpointChart.sendCommand(TempSetpoint.state)
rule "Heating Mode"
Item HeatingMode changed
switch(HeatingMode.state) {
case "ON": {
if (MyTempProxy.state < TempSetpoint.state) {
MainSwitch.sendCommand("ON")
HeatingPreviousMode="ON"
case "OFF": {
HeatingPreviousMode="OFF"
case "TIMER": {
HeatingPreviousMode="TIMER"
case "Boost": {
// See below more...
rule "Heating Timer"
Time cron "0 * * * * ?" or
TStartOne = new DateTime(now.getYear(), now.getMonthOfYear(), now.getDayOfMonth(), 6, 0, 0)
TEndOne = new DateTime(now.getYear(), now.getMonthOfYear(), now.getDayOfMonth(), 9, 0, 0)
TStartTwo = new DateTime(now.getYear(), now.getMonthOfYear(), now.getDayOfMonth(), 17, 0, 0)
TEndTwo = new DateTime(now.getYear(), now.getMonthOfYear(), now.getDayOfMonth(), 22, 0, 0)
if((HeatingMode.state == "TIMER") && ((now.isBefore(TEndOne)) && (now.isAfter(TStartOne)) || (now.isBefore(TEndTwo)) && (now.isAfter(TStartTwo)))) {
postUpdate(TempSetpoint, 20)
HeatingTimer.sendCommand("ON")
if((HeatingMode.state == "TIMER") && ((now.isAfter(TEndOne)) && (now.isBefore(TStartTwo)) || (now.isAfter(TEndTwo)) && (now.isBefore(TStartOne)))) {
postUpdate(TempSetpoint, 16)
if (HeatingMode.state == "ON") {
if (HeatingMode.state == "OFF") {
if (HeatingMode.state == "Boost") {
rule "MainSwitch"
Item MainSwitch changed
switch(MainSwitch.state) {
case ON:{
// Do nothing
case OFF:{
HeatingPreviousMode = "ON"
} else if (HeatingMode.state == "TIMER") {
HeatingPreviousMode = "TIMER"
} else if (HeatingMode.state == "Boost") {
//This should never execute
HeatingPreviousMode="Boost"
if (HeatingTimer.state == "ON") {
sitemap
Frame label="Heating" {
Switch item=HeatingMode mappings=[ "ON"="ON", "OFF"="OFF", "TIMER"="TIMER", "Boost"="BOOST"]
Text item=MyTempProxy
Setpoint item=HeatingBoostTime minValue=10 maxValue=1440 step=10 icon="clock"
/**CELSIUS*/ Setpoint item=TempSetpoint minValue=0 maxValue=40 step=0.5 icon="temperature"
//FAHRENHEIT Setpoint item=TempSetpoint minValue=32 maxValue=86 step=1 icon="temperature"
now the only thing I have changed is adding the TIMER and editing existing rules and items to suit the added function I not really great with these sorts of things and have put together this from a other few peoples projects but before I implement I wanted to know if it could be done any better or even work at all .
I am aware that some people don’t recommend using a timer but rather an event driven rule .
but ideally a timer/scheduler would really suit my needs.
Based on my rules “Heating Timer” my logic suggests this should if Timer is “ON”, turn the heating ON and set the temp at 20°C between the hours of 06:00 - 09:00 and 17:00 -22:00 and then set the temp to 16°C at all other times is this correct?
thank you in advance for any help .
