Have a Schlage Connect electronic lock. It’s detected by the Z-Wave stick as three things:
Node 3: Z-Wave Node 3: BE469 Touchscreen Deadbolt
Node 4: Z-Wave Node 4
Node 5: Z-Wave Node 5
… all showing as zwave:device:59841e71.
I Add any one of them and link whatever, and it pretends it works and is online. I change the setting User PIN to 6 digits, save, and it pops up Thing Updated, but then immediately “Error 500: Internal Server Error”. Still Online!
And it never shows up in Control. All my other Things show up and work. And this lock works great in Home Assistant. Key is set to the same as Home Assistant. What’s a nigga to do?
I’m assuming you are using OH 2.1, which doesn’t support Locks. The first few posts of the following thread will show you how to set up the test binding that does. Or you could wait, it may be merged into the nightly snapshot soon.
For those unwilling to wade through the infinitely-long thread, here is the short version:
Installing the -secure- ZWave binding:
1. Delete all Zwave Things from Habmin.
2. Uninstall the Zwave binding from HABmin. - You will NOT reinstall it.
3. Stop OH2
4. Make sure zwave is -not- in /var/lib/openhab2/etc/org.openhab.addons.cfg
5. www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-2.1.0-SNAPSHOT.jar
Copy the JAR file to your /usr/share/openhab2/addons folder.
6. Start OH2.
7. Log into Karaf ie... ssh openhab@localhost -p 8101
password is habopen
8. Start the zwave binding with: bundle:start org.openhab.binding.zwave
9. If get an error, you need to install the serial binding first: feature:install openhab-transport-serial
10. Now got back to Habmin, and Readd a Zwave Controller. Do NOT re-install the 2.0 Zwave Binding.
11. Set your USB port and rescan for devices.
12. To check that zwave binding is running check on Karaf console with list.
# ssh openhab@localhost -p 8101
password is habopen
openhab> feature:install openhab-transport-serial
openhab> list (and look for ZWave)
13. For discovery use HABmin as it will provide a popup if secure inclusion worked or not.
Unfortunately it didn’t work with my Schlage Connect lock. The ZWave binding now sees everything else automatically unlike before, like all my Leviton dimmers and switches, and Trane thermostats, but the three locks are unrecognized, even right next to the server. (Locks intentionally have a weak signal) I did a complete factory reset on two of the locks, and genned a new key for OH.
Maybe Nodes 3-5 are my locks:
.2017-07-03 10:14:27.946 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing 'zwave:device:4ac8b282:node11' takes more than 5000ms.
2017-07-03 10:16:56.501 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-07-03 10:16:56.501 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4ac8b282:node3' to inbox.
2017-07-03 10:16:56.521 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-07-03 10:16:56.541 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4ac8b282:node4' to inbox.
2017-07-03 10:16:56.544 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-07-03 10:16:56.547 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4ac8b282:node5' to inbox.
2017-07-03 10:17:51.324 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2017-07-03 10:17:51.337 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2017-07-03 10:18:28.405 [ERROR] [message.RemoveFailedNodeMessageClass] - NODE 3: Remove failed node failed!
2017-07-03 10:18:28.433 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 3: Is currently marked as failed by the controller!
2017-07-03 10:19:35.533 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2017-07-03 10:19:35.541 [ERROR] [message.RemoveFailedNodeMessageClass] - NODE 3: Remove failed node failed as node not found
That last entry, I tried to use HABmin to remove node 3 from the controller.
Examining the properties of nodes 3-5 they all show as zwave_class_specific SPECIFIC_TYPE_SECURE_KEYPAD_DOOR_LOCK
Of course, now that you have the new binding, the Schlage detection is actually broken. I had to set up an OH1 install to pair it, then copy the key over to my OH2 install. As long as you are using a USB zwave stick it works.
It’s actually the lock itself that does the state of the secure pairing by accepting the key from the controller. If you then take the USB zwave stick to another install, as long as you use the same key the pairing will be secure. Some people have used domotics to pair the Schlage Connect. The maintainer of the binding is working on it.
Gotta warn people against trying the new ‘security’ ZWave binding – nothing works. At least none of my Leviton dimmers and switches, Trane thermostats, nor Schlage door locks.
Report your issues and reproduction steps in the thread so Chris can take a look. The Schlage thing is a known issue that he is working on figuring out and more info is always helpful. If the locks work in HASS then you should just be able to plug the zstick in an OH2 machine, copy the key used in HASS to the OH2 zstick Thing and discover the lock Thing. But if your other devices aren’t working, it may be a configuration issue. There can be a problem with the online binding not uninstalling correctly and your OH2 install trying to run 2 bindings.
pulling my hair out. I know this post is old but it’s the closes I can find to pairing a Schlage lock (BE469) with OpenHAB2 using a Aeon Gen5 ZStick.
How do you pair the zstick with the lock?
Do I unplug the stick and pair it with the lock or
Do I use openHAB2’s Inbox scan and while that scan is happening, do I put the lock in pair mode?
If I unplug the zstick and put it in pairing mode next to the door lock, it pairs up OK but then nothing works in openHAB2. I assume this has to do with the network key
NOTE: In openhab2, I have tried pairing with the lock using the zstick in network wide mode, high power mode, and low power mode and none of them work this way.
I’m confused as to whether or not openHAB2 puts the zstick in pairing mode when you go to the Inbox and scan for new devices. Specifically, I click on the Inbox, then the plus sign, I chose z-wave bindings, and while that searching graphic is shown I try to put the lock in pairing mode. This always fails. Yet I can’t find any documentation, not even on the openhab site, that explains this process in any amount of detail.
I wish someone would put the dots real close together as in a step-by-step how-to. I am so close to ditching openHAB and starting my own open source project. Restarting openHAB2 java takes several minutes on a raspberry pi which seems utterly ridiculous to me.
I just paired mine last night with some difficulty. “Eye of newt” solution:
Do NOT include using walk-around mode – keep z-stick inserted in Pi and use Paper (or Habmin) search for Z-wave devices
Put Paper/Habmin in Search mode and IMMEDIATELY put lock in pairing mode – you only have a few seconds to do this
The lock will include (INSECURELY) at a greater physical distance from the Pi-z-stick combo than it will include SECURELY. I literally moved my Pi-stick to about six feet from the lock to get it to include securely. (twenty-five feet and a wall away – no joy)
(N.B. if you get an INSECURE inclusion, be sure to delete it before retrying)
Has this continued to work for you? I had this unreliably working on openhab instance I had running on Windows, (Not work more often) Hoping to get more reliability on Raspberry Pi I moved my openhab setup to that. No problem with my other z-wave devices, but for the lock it doesn’t work at all now. It shows as online, but I do not get update from battery level nor am I able to lock it remotely. I tried a factory reset on th ock and re-enrolling, but no luck. Strange thing is openhab finds the lock in the Inbox before I initate the enroll on the lock (recently factory reset). I suspect something might be cached in openhab, but I don’t know how to start over.
This thread is a lifesaver. I have been able to get one Schlage lock added, though there’s still some question for me as to what the undefined controller node is that’s associated with it. I’m assume it relays signals, but perhaps the discovery process just isn’t complete..
FWIW, in my case, I had to un-enroll the lock 3 times before it stopped showing up in PaperUI, per @bob_dickenson’s directions. It did, however, eventually give it up. One more to go… Thanks to the community on this one.
