I have recently purchased a Schlage FE599NX zwave lock. I’m running with the ZWave binding 2.5.0.201901061034. I believe that should include the security features. I put the z-stick into inclusion mode from paper UI. I can lock and unlock the lock from the controller. I can send new User codes to the device. But when a user enters a code at the lock itself it doesn’t get registered with the controller. I get the response below about the response not being security encapsulated.
Has anyone had any luck with this Lock? Is this an issue with the item database? Should the Command Class Basic not have a check under Sec?
I also don’t seem to get any notification when the Lock and Unlock button are pressed on the lock itself.
01:53:21.669 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 49 84 14 07 04 40 03 85 73 72 98 77
01:53:21.672 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=20, callback=132, payload=84 14 07 04 40 03 85 73 72 98
01:53:21.673 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=20, callback=132, payload=84 14 07 04 40 03 85 73 72 98
01:53:21.674 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null
01:53:21.675 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
01:53:21.676 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Last transaction: null
01:53:21.677 [DEBUG] [ave.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=20, callback=132, payload=84 14 07 04 40 03 85 73 72 98
01:53:21.678 [DEBUG] [message.ApplicationUpdateMessageClass] - NODE 20: Application update request. Node information received. Transaction null
01:53:21.679 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 20: resetResendCount initComplete=true isDead=false
01:53:21.679 [DEBUG] [message.ApplicationUpdateMessageClass] - NODE 20: Application update - no transaction.
01:53:21.681 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
01:53:21.681 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
01:53:30.027 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 14 03 20 01 FF 3B
01:53:30.028 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=20, callback=0, payload=00 14 03 20 01 FF
01:53:30.030 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=20, callback=0, payload=00 14 03 20 01 FF
01:53:30.031 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null
01:53:30.032 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 20: Application Command Request (ALIVE:DONE)
01:53:30.033 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 20: resetResendCount initComplete=true isDead=false
01:53:30.034 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 20: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
01:53:30.035 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 20: SECURITY required on COMMAND_CLASS_BASIC
01:53:30.035 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 20: Command Class COMMAND_CLASS_BASIC was required to be security encapsulated but it wasn't! Message dropped.
01:53:30.036 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 20: Commands processed 0.
01:53:30.037 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
01:53:30.038 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
