Has anyone attempted to integrate the Schlage Sense door lock into OH2? It appears the only method of integration will be via Bluetooth, however I have had no luck thus far. The sense appears to be the only line of connected locks from Schlage that utilizes Bluetooth rather than Z-wave. The limited amount of info in the OH community all focuses on the Zwave models which is why I started a new topic.
What type of bluetooth? BLE? Note that bluetooth, especially door locks, have authentication (differs by manufacturer). For example, to control an August lock using its BLE, you would need to know the offline key.
I can not confirm if it’s BT LE as its nowhere published in any of the spec documentation.
