Hello Folks,
for those who may hesitate to buy a Schwaiger ZHS06!
Hello Folks,
I just want you inform that “Schwaiger ZHS06 Motion Sensor” = “Fibaro FGMS001 Motion Sensor” and it is running with OH2. It is detected as “FGMS001 Motion Sensor”.
In z-wave database it is the following device:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/115
Have fun!
P.S. Many thanks to @sihui
@chris Should we put this into your database?
If I understand correctly, it is already there? Above you said it is detected as a “Fibaro FGMS001”? If that’s correct, then it’s already in the database.
@chris Yes, it is in your database, but it is also sold in Germany under brand name “Schwaiger” ZHS06 and not under brand name Fibaro. see here: link. Maybe some people get confused by this or they may hesitate to buy one?
Schwaiger also has: Flood Sensor (ZHS07) = Fibaro FGFS-101: see here link
and Schwaiger Wall Plug (ZHS13) = Fibaro FGWPx-101: see here link
and many other products that look like Fibaro. But I didn’t test ZHS07 and ZHS13 with OH2.
Maybe it is possible to put a hint into your database, that Fibaro also is branded under “Schwaiger”?
Ok, but this is still a Fibaro device, so there’s no way for the binding / database to know the difference since the manufacturer is reported as a Fibaro.
The only thing I can suggest is to add a comment in the description.
@chris It’s up to you. If you think it makes sense, write it down there. Thanx. .
