Script execution of rule failed: 'sendHtmlMail' is not a member of 'org.openhab.core.thing.binding.ThingActions'
  • Platform information:
    • Hardware: RPI5
    • OS: openhabian
    • Java Runtime Environment: 21
    • openHAB version: 5.1.0
Hi everyone,
Since updating to openHAB 5.1.0, all of my rules that use the Mail Binding are failing. No email is being sent. The error in the log always looks roughly like this:
“Script execution of rule failed: ‘sendHtmlMail’ is not a member of ‘org.openhab.core.thing.binding.ThingActions’”
import java.util.List
rule "eingangsklingel betätigt"
	Item Eingangsklingelsensor changed from OFF to ON
	logInfo("KLINGEL","Klingeltaste gedrueckt")
	executeCommandLine(Duration.ofSeconds(60), "/etc/openhab/scripts/klingel.sh")
	val List<String> attachmentUrlList = newArrayList("file:///webcam/klingel.jpg")
	val mailActions = getActions("mail","mail:smtp:a5d5920d8a")
	var success = mailActions.sendHtmlMail("mail.sender@mailserver.de",
								"Es hat geklingelt",
								"<h1>Mitteilung</h1>Es hat um "  + now.toString().substring(11,16) + " Uhr an der Haustür geklingelt.",
								attachmentUrlList
	if (success) logInfo("MAIL","Klingel-Mail versandt")
Another rule using “.sendlMail” shows naerly the same error in my log. Script execution of rule failed: ‘sendMail’ is not a member of ‘org.openhab.core.thing.binding.ThingActions’
A sudo openhab-cli clean-cache and a restart did not help. What else can I do?
Best regards, Volker
Is the SMTP Thing mail:smtp:a5d5920d8a online?
Is the Mail binding installed?
It’s possible this changed, but looking at the docs for the Mail binding, if you are sending an email with attachments there’s a different action to call.
sendHtmlMailWithAttachment(String recipient, String subject, String htmlContent, List<String> urlList)
thanks for the reply.
the smtp binding is online. The Actions under Configuration-TAB are working … With 5.0 mails are send successfully.
And yet, according to the docs for 5.1, to send attachments you must use sendHtlmMailWithAttachment, not sendHtmlMail.
None of this has changed so I can’t tell you why it worked in 5.0 for you. But according to the docs for both 5.0 and 5.1, you need to use a different action. There is no sendHtmlMail action that takes four arguments.
changing to ‘sendHtlmMailWithAttachment’
	Aussenlampen.sendCommand(ON)												//Aussenlampen einschalten
	habdisplay.sendCommand(ON)													//habdisplay einschalten schaltet automatisch wieder aus
	homePageItem.postUpdate("cam_motioneye_vorne")								//webcam Haustür als Seite im Habpanel anzeigen
	var success = mailActions.sendHtlmMailWithAttachment("x.x@mailserver.de",
								attachmentUrlList
endode goes here
the log error is:
Script execution of rule with UID ‘eingangsklingel-1’ failed: ‘sendHtlmMailWithAttachment’ is not a member of ‘org.openhab.core.thing.binding.ThingActions’; line 16, column 16, length 250 in eingangsklingel
Be careful with copy and paste from the forum.
See the difference?
hmm, copy&paste error, sorry for this, my fault. Next try with .sendHtmlMailWithAttachments ….
rule "eingangsklingel betaetigt"
	var success = mailActions.sendHtmlMailWithAttachments("x.x@mailserver.de",
								attachmentUrlList
with .sendHtmlMailWithAttachments the result is same.
Script execution of rule with UID ‘eingangsklingel-1’ failed: ‘sendHtmlMailWithAttachments’ is not a member of ‘org.openhab.core.thing.binding.ThingActions’; line 16, column 16, length 251 in eingangsklingel
Thank you for the help. The mail binding is now working after a third or fourth sudo reboot now. I still have no idea why multiple reboots were necessary for it to work.
    Time
    15:00:30.176
    Timestamp
    Jan 7, 2026, 3:00:30 PM
    Level
    INFO
    Logger Class
    org.openhab.core.model.script.MAIL
    Message
BR
Volker
As this is openHAB 5.1. a new immutable List can be created with the shorter form #["file:///webcam/klingel.jpg"] instead of newArrayList("file:///webcam/klingel.jpg"). See Xtend - Expressions - Collection Literals.
In now.toString().sub… the brackets () can be skipped: now.toString.substring(11,16) — reference Xtend - Expressions - Field Access and Method Invocations.
