Script execution of rule with UID 'xxxxxxx' failed: Could not cast 10 W to org.openhab.core.library.types.DecimalType; line 1, column 23, length 40
I now it has something to do with the breaking change of 3.4.0 (just upgraded…), but don’t know how to fix it.
The items which are used to do some calculations are
Number:Power                mqtt_sofar_pv1Power                 "PV1 Power"                 (sofarsolar)    ["Status","Energy"]    {channel="mqtt:topic:mosquitto2:sofar:pv1Power"}
Number:Power                mqtt_sofar_pv2Power                 "PV2 Power"                 (sofarsolar)    ["Status","Energy"]    {channel="mqtt:topic:mosquitto2:sofar:pv2Power"}
and in the rule I always used started with this:
var Number pv1Power = mqtt_sofar_pv1Power.state as DecimalType
var Number pv2Power = mqtt_sofar_pv2Power.state as DecimalType
But this gives the error: Script execution of rule with UID 'xxxxxxx' failed: Could not cast 10 W to org.openhab.core.library.types.DecimalType; line 1, column 23, length 40
loginfo of item: mqtt_sofar_pv1Power (Type=NumberItem, State=10 W, Label=PV1 Power, Category=null, Tags=[Status, Energy], Groups=[sofarsolar])
output of API
  "link": "https://xxxxxxxxx.com/rest/items/mqtt_sofar_pv1Power",
  "state": "0 W",
  "stateDescription": {
    "step": 1,
    "pattern": "%s %unit%",
    "readOnly": true,
    "options": []
  "editable": true,
  "type": "Number:Power",
  "name": "mqtt_sofar_pv1Power",
  "label": "PV1 Power",
  "tags": [
    "Status",
    "Energy"
  "groupNames": [
    "sofarsolar"
I managed to solve this by changing the item from Number:Power to Number, but is this the way-to-go?
If I use numbers with units…
(item.state as Number).floatValue
This is working too.
(item.state as QuantityType<Number>).doubleValue
Here I can do math and such nice things :slightly_smiling_face:
Greets
Number:Power UoM-typed numbers are QuantityType<Power> of data type so you cannot cast them to a DecimalType.
Use as Number. Avoid .floatValue that’ll create huge processing delays. But it’s a very complex topic, you need to go understand the implications of using UoM, Units of Measurement, read the docs on that.
So my 2 examples should work without the floatValue?
Greets
Depends on context, as I said you have to understand the implications of using UoM. You have to find out yourself.
Ok, I changed my items back to Number:Power and modified my rules to item.state as Number.
Is working!
