======================================= my_sysinfo - Start ========================================================
******* Hardware-Info = model name : ARMv7 Processor rev 3 (v7l)
******* Hardware-Info = Model : Raspberry Pi 4 Model B Rev 1.1 / 2 GB
=========================================== Linux Version ==========================================================
******* Linux-Version-Info = Raspbian GNU/Linux 10 (buster) (Pretty-Name)
===================================== Openhab-Version Info =========================================================
******* OH-Version-Info = openHAB Distribution Version Information
******* OH-Version-Info = ----------------------------------------
******* OH-Version-Info = build-no : Release Build
******* OH-Version-Info = online-repo : https://openhab.jfrog.io/openhab/libs-release
******* OH-Version-Info = Repository Version
******* OH-Version-Info = openhab-distro : 2.5.9
******* OH-Version-Info = openhab-core : 2.5.0
******* OH-Version-Info = openhab1-addons : 1.14.0
******* OH-Version-Info = openhab2-addons : 2.5.9
******* OH-Version-Info = karaf : 4.2.7
===================================== Jython-Parameters (Scott) ==================================================
******* Jython-Version = 2.7.2.final
******* os.name = Linux
******* os.version = 5.4.51-v7l+
******* java.vendor = Azul Systems, Inc.
******* java.vm.name = OpenJDK Client VM
******* java.runtime.name = OpenJDK Runtime Environment
******* java.runtime.version = 1.8.0_265-b11
******* sys.path = /etc/openhab2/automation/lib/python
/etc/openhab2/automation/jython/Lib
/etc/openhab2/automation/jython/jython-standalone-2.7.2.jar/Lib
__classpath__
__pyclasspath__/
******* java.external.dirs = /opt/jdk/zulu8.48.3.246-ca-jdk8.0.265-linux_aarch32hf/jre/lib/ext:/opt/jdk/zulu8.48.3.246-ca-jdk8.0.265-linux_aarch32hf/lib/ext:/usr/share/openhab2/runtime/lib/ext
******* file.encoding = UTF-8
******* jetty.host = 0.0.0.0
Early this year I began to migrate my DSL-Rule-driven OH-System to Scripted Automation (JSR223) on a RPi3b with a minimal Item-Setup and everything seems to be fine. The Mosquitto-Broker is running on my Main System.
I upgrated the openHAB-Releases on my Main-System and on the JSR223-System. Now Iβm on OH2.5.9
Now I moved my JSR223-System to a RPi4/2GB and installed the complete Setup (Items, etc) to it. But after a while (some hours) AVM-Binding and Homematic-Binding sometimes to are losing connection, but I donβt know why.
logging:
2020-09-30 10:57:19.649 [INFO ] [jsr223.ohtest.Moon distance ] - Moondistance updated every 5 Minutes Date_distance / Mi, 30.Sep. / 1 Log every 2 hours
2020-09-30 10:58:18.467 [INFO ] [jsr223.ohtest.OpenWeatherMap_list ] - 2 End Rule - I'm still alive - Log Count is 4
2020-09-30 11:00:48.934 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection lost on gateway '3014F711A0001F98A9AABCAF', cause: "IOException java.util.concurrent.ExecutionException: java.net.SocketException: Could not connect to /192.168.178.80:2001"
2020-09-30 11:01:29.417 [INFO ] [ommunicator.AbstractHomematicGateway] - Connection resumed on gateway '3014F711A0001F98A9AABCAF'
2020-09-30 11:02:59.598 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2020-09-30 11:04:59.748 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2020-09-30 11:06:59.893 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2020-09-30 11:09:00.024 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2020-09-30 11:10:30.079 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2020-09-30 11:28:16.784 [INFO ] [jsr223.ohtest.windchill ] - I'm alive - Windspeed: 2.77 km/h Temperature: 13.13
2020-09-30 11:57:32.811 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:57:32.820 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 11:57:47.813 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:57:47.819 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 11:58:02.826 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:58:02.842 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 11:58:17.852 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:58:17.872 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 11:58:18.495 [INFO ] [jsr223.ohtest.winddirection ] - I'm alive - Direction-Name: West Direction-Degree: 261.0 Β°
2020-09-30 11:58:32.868 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:58:32.877 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 11:58:47.885 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 11:58:47.897 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 12:20:00.761 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@1bb5b58 from discovery topic homeassistant/# on broker mqtt:broker:fritz but topic not registered for listener. Check discovery logic!
2020-09-30 12:20:00.774 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@86efa5 from discovery topic +/+/$homie on broker mqtt:broker:fritz but topic not registered at all. Check discovery logic!
2020-09-30 12:20:00.777 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@86efa5 from discovery topic homeassistant/# on broker mqtt:broker:fritz but topic not registered at all. Check discovery logic!
2020-09-30 12:20:00.779 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@86efa5 from discovery topic +/+/$homie on broker mqtt:broker:fritz but topic not registered at all. Check discovery logic!
2020-09-30 12:20:01.797 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-09-30 12:20:02.209 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been shut down
2020-09-30 12:20:04.571 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond., Thing Detail is : OFFLINE
2020-09-30 12:20:04.586 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : OFFLINE (COMMUNICATION_ERROR): Request is invalid, Thing Detail is : OFFLINE
2020-09-30 12:20:08.243 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : UNINITIALIZED, Thing Detail is : UNINITIALIZED
2020-09-30 12:20:08.257 [WARN ] [jsr223.ohtest.avm status check ] - Fritz-Box - Thing Status changed to : UNINITIALIZED (HANDLER_MISSING_ERROR), Thing Detail is : UNINITIALIZED
2020-09-30 12:20:13.448 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing 'homematic:bridge:3014F711A0001F98A9AABCAF' takes more than 5000ms.
2020-09-30 12:20:18.909 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing 'samsungtv:tv:test' takes more than 5000ms.
2020-09-30 12:20:38.496 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[qtp3713480]@38a9c8{STOPPING,8<=0<=200,i=3,r=-1,q=5}[NO_TRY] Couldn't stop Thread[qtp3713480-34701,5,main]
2020-09-30 12:20:38.499 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[qtp3713480]@38a9c8{STOPPING,8<=0<=200,i=3,r=-1,q=5}[NO_TRY] Couldn't stop Thread[qtp3713480-34702,5,main]
I also have to say that my Helper Libraries are not the latest version - I think ![]()
Does anyone has a similar behavior or can give me a hint ? Thx in advance.
Cheers
Peter
