I’m about to endevour on moving to a build with jsonDB, before I bite the bullet, I’m wondering if anyone has created a converter to collect all their configs from a mixture of database/textual files. Using the REST interface, I can create the following bash script that moves all my items to one file. For this you’d need to install (apt-get) “jq”.
###Input
curl -s http://localhost:8080/rest/items/ | jq '.[] | .type + "\t" + .name
+ (if (.label | length) != 0 then
("\t\"" + .label + "\"")
else "" end)
+ (if (.category | length) != 0 then
("\t<" + .category + ">")
else "" end)
+ (if (.groupNames[0] | length) != 0 then
("\t(" + ((.groupNames | . ) | join(",")) + ")")
else "" end)' --raw-output > fromDB.items
###Output
Number Bedroom_MotionSensor_Luminance "Luminance [%.1f lux]" <Slider>
Switch Bedroom_MotionSensor_Motion "Motion [MAP(sensor.map):%s]" <switch> (Group_RestoreOnStartup)
Number Bedroom_MotionSensor_Temperature "Temperature [%.1f °C]" <Temperature>
Switch Ben_Phone_Online "Online" <network>
Number DiningRoom_DesktopPower_Current "Current [%.1f A]" <Energy>
Number DiningRoom_DesktopPower_EnergyConsumption "Energy Consumption [%.1f kWh]" <Energy> (Group_RestoreOnStartup)
Number DiningRoom_DesktopPower_PowerConsumption "Power Consumption [%.1f W]" <Energy>
Number DiningRoom_DesktopPower_PowerFactor "Power Factor" <Energy>
Switch DiningRoom_DesktopPower_Switch "Switch" <Switch> (Group_RestoreOnStartup)
[..etc]
This fails at doing two things
- Groups do not keep their function parameter. (Which could be solved using a nest if-then or maps above)
- Items lose their channel links.
Anyone have any additions? If not I can use the output of the above script as a guide to begin anew and I hope someone finds it just as helpful.
