- Platform information:
- Hardware: Raspi 4
- OS: Linux openhabian 6.1.21
- Java Runtime Environment: openjdk version “17.0.9” 2023-10-17
OpenJDK Runtime Environment (build 17.0.9+9-Raspbian-1deb11u1rpt1)
OpenJDK Client VM (build 17.0.9+9-Raspbian-1deb11u1rpt1, mixed mode, emulated-client) - openHAB version: 4.1.1 - release build
- Issue of the topic:
I did perform a fresh setup to migrate to OH4. Used a new SD card with the following image:
openhabian-pi-raspios32-202402051947-git4f124c2-crc903d2975.img.xz
Nothing changed there, performed initial setup, when OH was up and running installed successfully Phoscon, Mosquitto, Samba and loaded the previous config from OH 3.3.
System runs - I’m quite happy. Decided to organize the first half of the backup strategy - SD copy - using Option 53.
Obviously the installation was successfull, the new (twice the size) card was partitioned with 3 partitions.
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 59.5G 0 disk
├─sda1 8:1 1 256M 0 part
├─sda2 8:2 1 29.6G 0 part
└─sda3 8:3 1 29.6G 0 part /storage
mmcblk0 179:0 0 29.8G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 29.6G 0 part /
zram0 254:0 0 1G 0 disk [SWAP]
zram1 254:1 0 750M 0 disk /opt/zram/zram1
zram2 254:2 0 1G 0 disk /opt/zram/zram2
Sdrawcopy seems did run (at least it took half an hour or so and the success was reported). Timers are set and obviously the sdrsync.service did run
systemctl list-timers
NEXT LEFT LAST PASSED UNIT ACTIVATES
Thu 2024-02-22 20:39:02 CET 2h 17min left Wed 2024-02-21 20:39:02 CET 21h ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Fri 2024-02-23 00:00:00 CET 5h 38min left Thu 2024-02-22 00:00:02 CET 18h ago exim4-base.timer exim4-base.service
Fri 2024-02-23 00:00:00 CET 5h 38min left Thu 2024-02-22 00:00:02 CET 18h ago logrotate.timer logrotate.service
Fri 2024-02-23 00:00:00 CET 5h 38min left Thu 2024-02-22 00:00:02 CET 18h ago man-db.timer man-db.service
Fri 2024-02-23 02:07:20 CET 7h left Thu 2024-02-22 02:07:02 CET 16h ago sdrsync.timer sdrsync.service
Fri 2024-02-23 05:01:30 CET 10h left Thu 2024-02-22 03:54:57 CET 14h ago firemotd.timer firemotd.service
Fri 2024-02-23 05:03:26 CET 10h left Thu 2024-02-22 11:41:22 CET 6h ago apt-daily.timer apt-daily.service
Fri 2024-02-23 06:50:13 CET 12h left Thu 2024-02-22 06:30:24 CET 11h ago apt-daily-upgrade.timer apt-daily-upgrade.service
Sun 2024-02-25 03:10:06 CET 2 days left Sun 2024-02-18 03:10:59 CET 4 days ago e2scrub_all.timer e2scrub_all.service
Mon 2024-02-26 00:23:46 CET 3 days left Mon 2024-02-19 00:13:09 CET 3 days ago fstrim.timer fstrim.service
Mon 2024-07-01 01:15:00 CEST 4 months 7 days left Sun 2024-02-11 13:48:33 CET 1 weeks 4 days ago sdrawcopy.timer sdrawcopy.service
11 timers listed.
Pass --all to see loaded but inactive timers, too.
But I don’t see any files stored - although I did change one file in Home directory on purpose - just as test. I thought the changed files would land in sda3 mounted as storage - but its completely empty.
openhabian@openhabian:~ $ cd /storage
openhabian@openhabian:/storage $ ls
lost+found syncmount
openhabian@openhabian:/storage $ cd syncmount/
openhabian@openhabian:/storage/syncmount $ ls
Any hint? Is there a logfile where I would see the reason?
Cheers and thanks Frank
