Second channel returns NULL
  • Platform information:
    • RASPI 4
    • Rasberian
    • Java Runtime Environment: 11
    • openHAB version: 3
  • Issue of the topic: Sencond channel of a tasmota switch show NULL
I defined a thing with two channels using mqtt bindings. The first channel provides the correct value, the second shows always NULL.
What did I wrong ?
UID: mqtt:topic:35b9925914
label: GS-55 Total
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:minion_mqtt
channels:
  • id: gs_55_sensor_total
    channelTypeUID: mqtt:number
    label: gs_55_sensor_total
    description: “”
    configuration:
    commandTopic: ‘“cmnd/gosound_switches/gosound-55/STATUS 8”’
    formatBeforePublish: “%.4f”
    stateTopic: stat/gosound_switches/gosound-55/STATUS8
    transformationPattern: JSONPATH:$.StatusSNS.ENERGY.Total
  • id: gs_55_sensor_today
    label: gs_55_sensor_today
    description: “”
    configuration:
Without having such a device we would at least need an example of the full Status8 message you are receiving.
{“StatusSNS”:{“Time”:“2021-07-14T08:14:20”,“ENERGY”:{“TotalStartTime”:“2021-07-03T14:29:02”,“Total”:0.659,“Yesterday”:0.054,“Today”:0.001,“Power”:4,“ApparentPower”:7,“ReactivePower”:6,“Factor”:0.59,“Voltage”:220,“Current”:0.034}}}
Did you by chance change the type manually in the YAML? This won’t work, and you have to delete and recreate the Channel.
This shouldn’t be the issue but both your Channels are extracting Total
No, I didn’t change the YAML
Yes, for testing purposes I configured exact the same Pattern, that’s why I wonder why the first work, the second not. I also tired with Pattern “JSONPATH:$.StatusSNS.ENERGY.Today” and got the same result: NULL
Could you reformat your first post and copy/paste your configuration in-between code fences?
Have you linked both Channels to distinct Items?
Yes both have dedicated items
label: GS-55 Total
configuration: {}
channels:
    description: “”
    configuration:
    description: “”
    configuration:
Missing on second channel maybe?
makes no difference, either the result is handled as string or as float
 I tried both
formatbeforepublish has nothing to do with incoming state topics.
Make sure you have not applied profile to your channel-Item links by accident.
Bindings are not always that clever about actioning in-flight edits. After all this editing, when you’ve got your best guess set up, try a restart.
I tried to restart and suddenly I get the value, BUT
when I change something in the second channels it will not be shown neither the value nor the unit, even when I restart
it looks now:
label: GS-55 Total
configuration: {}
channels:
  - id: gs_55_sensor_total
    description: ""
    configuration:
      commandTopic: '"cmnd/gosound_switches/gosound-55/STATUS 8"'
      unit: kWh
      formatBeforePublish: "%.4f"
  - id: gs_55_sensor_today
    description: ""
    configuration:
      unit: kWh
      transformationPattern: JSONPATH:$.StatusSNS.ENERGY.Today
Good.
What type of Item are you linking to? You may not be aware that MQTT channel parameter unit:kWh is currently not applied to incoming data (that is being worked on), only to outgoing messages.
So the change you made is suspect. That would look to be your JSONPATH. What does your incoming message payload look like?
The incoming message is:
Looks fine to me. You know this works in general now, and it’s either a mistake in config or Item linking, or your edits not yet taken into account.
Is possible to export items and channels as json/yaml objetcs, so I can compare them?
or copy an item into an other ?
See the tool API explorer for JSON representation.
Found the reason:
JSONPATH:$.StatusSNS.ENERGY.Today must be trigger manually
JSONPATH:$.ENERGY.Today is triggered periodically by the device
