Secure Frontail
(Ferry) #1
I would like to secure frontail by means of a login. Is this possible? I can not find it.
I found this on Github but I do not know where to put this in my openhabian installation.
Or is it possible for frontail not to start automatically?
(Anders Alfredsson) #2
This is probably the easiest option.
(Rich Koshak) #3
It’s important to understand that Frontail is not part of openHAB. openHABian does install it and configure it to watch openHAB’s logs but beyond that it’s just a standard install of Frontail.
So any tutorial you find or software or configuration setting you find will work.
You can make it not start automatically by running
sudo systemctl disable frontail
(Ferry) #4
The easiest is indeed not to start the service.
Thank you.
(Rich Koshak) #5
I think you can remove it entirely from openhabian-config.
