Hi, I am on openHab 3.1.0 and I can’t add it to my homekit.
The message I get from homekit is
Security check failed or action not allowed
I have tried some basic troubleshooting but could not solve. I have also tried to change the port and the PIN but it did not work. I’ve never added it before, so it’s not a conflict with a previous addition. Command log:display does not return any error for homekit or anything interesting in general.
My openHab runs on Synology with Docker and uses the host network. The homekit port is exposed as far as I can see, so it’s not reachability issue. Any more step I can try?
I have an update. I was able to pair HomeKit and openHab.The message was misleading, but apparently my HomeKit had an orphan accessory belonged to a previous addition of openHab. I could not identify it immediately because the openHab does not come up in the list of bridges.
Accessories are correctly seen, but the bridge is not listed. Not sure this is an intended behaviour or not.
