i am germany based - and need to invest in some air conditioning wihtin some rooms of my house. I want to integrate this one into openhab - as i want to active clima control when photovoltaik is producing enough power to run isolated from external power grid.
Is there any suggestion/ binding to take for integrating an air conditioning system into OH 1.x/ 2? I am currently still open to any system.
Also it’s already heating season I like to add another suggestion here:
I used KNX adapters (IntesisBox) to link our Mitsubishi AC to openHAB via the standard KNX binding.You can control and query every relevant parameter of the AC (on/off, mode, fan, vane, temp, error, scene).
These adapters are also available for other brands of AC like Daikin, Fujitsu, LG, Panasonic or Toshiba. The only drawback is that you need a KNX bus installation
could you please elaborate a bit more on your KNX based solution? I have no experience with it and would like to know how you linked your Mitsubishi AC to OpenHAB.
I myself have four Mitsubishi Heavy industries SRK-25 indoor AC devices and would like to control them. Do I need a box for each of them and how do I actually connect them with the box?
I would be very thankful if you could enlighten me a bit.
the Intensis Box is a aftermarket KNX interface for a variety of AC vendors. You’ll find more info about the box and supported ACs here: https://www.intesisbox.com/
This gives openHAB access to AC via the KNX binidnig…
