I have a simple setup with a couple of rooms with each of them having one light or more, then, what i would like to do is control all lights within a given room. But i have searched around for a while now and can’t find a way to select multiple groups.
Example of what i want to do:
.items file with the items available to control. Note the parent groups for each.
Then, what i want to do is select all the two lights in the gBedroom group, without selecting the light from the office or the chromecast volume control. Something along the lines of the following:
Sorry, my bad, i forgot to mention there are other items in the gBedroom group, such as a volume slider. Which i guess would also be controlled if i selected the whole group.
Just add as much groups as you like, e.g. create a group gBedroomLights. Whenever you want a functional unit, create a group for that purpose. You may also put single items on your sitemap, you are nto restricted to groups.
