Doesn’t sort work with 1 and -1? It appears to fail when I use Booleans.
Aha, interesting!
Idem
I don’t quite understand how to combine this with e.g. time.toZDT("08:00")…
I’m sure it’s got value, but I don’t know how this works, and I’ve got a feeling it’s not ideal for my scenario, where not all days require the same alarm clock.
I tried implementing this, but I don’t really understand the syntax. Trying snippets of it in a scratchpad threw errors/exceptions. So for now, I’m sticking with the syntax I understand.
I was actually too tunnel-visioned. There’s no need for all these different DateTime Items, a simple look-up object does the trick. If my work schedule changes, I’ll just change the object.
New attempt:
var controleperiode = 18; // in uren
var schoolwekkers = {
monday: "05:45",
tuesday: null,
wednesday: "06:00",
thursday: "06:00",
friday: "05:45",
saturday: null,
sunday: null
var eenmaligewekkers = items["wekker_openhab"];
var wekker_schoolwekkers_actief = items["wekker_schoolwekkers_actief"];
var wekker_vakantiewekkers_actief = items["wekker_vakantiewekkers_actief"];
var begin_volgende_schoolvakantie = items["begin_volgende_schoolvakantie"];
var einde_huidige_schoolvakantie = items["einde_huidige_schoolvakantie"];
var wekker_school = items["wekker_school"];
var wekker_vakantie = items["wekker_vakantie"];
var eenderwelkewekkermorgen = false;
var wekkersmorgen = {
schoolwekkermorgen: false,
vakantiewekkermorgen: false,
eenmaligewekkermorgen: false,
eenmaligewekkers: []
var nu = time.toZDT();
function wekkersSorteren(a, b) {
if (time.toZDT(a).isBefore(time.toZDT(b))) {
return -1;
} else {
return 1;
function wekkerSelecteren(wekkers) {
if (wekkers.length > 1) {
var melding = "Er is voor morgen meer dan één wekker ingesteld; enkel de vroegste wordt geactiveerd."
console.log(melding);
rules.runRule("melding_gsm_DBE", { 'melding': melding });
wekkers.sort(wekkersSorteren);
return wekkers[0];
function schoolWekkerActief() {
if
wekker_schoolwekkers_actief.boolState
!begin_volgende_schoolvakantie.isUninitialized
!time.toZDT(begin_volgende_schoolvakantie).toLocalDate().equals(nu.plusDays(1).toLocalDate())
(!einde_huidige_schoolvakantie.isUninitialized && time.toZDT(einde_huidige_schoolvakantie).toLocalDate().equals(nu.toLocalDate()))
wekker_vakantiewekkers_actief.sendCommandIfDifferent("OFF");
return true;
} else {
return false;
function wekkerVoorMorgen() {
var schoolwekkeractief = schoolWekkerActief();
if (schoolwekkeractief) {
var weekdagmorgen = String(time.toZDT("P1D").dayOfWeek()).toLowerCase();
if (schoolwekkers[weekdagmorgen] != null) {
eenderwelkewekkermorgen = true;
wekkersmorgen["schoolwekkermorgen"] = true;
var schoolwekkermorgen = time.toZDT(schoolwekkers[weekdagmorgen]).plusDays(1);
wekker_school.sendCommand(schoolwekkermorgen);
} else if (wekker_vakantiewekkers_actief) {
var nieuwevakantiewekker = vakantieWekkerInstellen();
var controlemoment = nu.plusHours(controleperiode);
for (var x = 0; x < eenmaligewekkers.length; x++) {
var dezewekker = eenmaligewekkers[x];
if (!dezewekker.isUninitialized && time.toZDT(dezewekker).isBefore(controlemoment)) {
wekkersmorgen["eenmaligewekkermorgen"] = true;
wekkersmorgen["eenmaligewekkers"].push(dezewekker);
if (eenderwelkewekkermorgen) {
if (wekkersmorgen["eenmaligewekkermorgen"]) {
var uiteindelijkewekker = wekkerSelecteren(wekkersmorgen["eenmaligewekkers"]);
items["wekker_eerstvolgende"].sendCommand(uiteindelijkewekker.state);
if (wekkersmorgen["schoolwekkermorgen"]) {
var melding = "Er is voor morgen een eenmalige wekker ingesteld; de normale schoolwekker wordt dus genegeerd.";
meldingDBE(melding);
} else if (wekkersmorgen["vakantiewekkermorgen"]) {
var melding = "Er is voor morgen een eenmalige wekker ingesteld; de normale vakantiewekker wordt dus genegeerd.";
} else if (wekkersmorgen["schoolwekkermorgen"]) {
items["wekker_eerstvolgende"].sendCommand(schoolwekkermorgen);
} else if (wekkersmorgen["vakantiewekkermorgen"] && nieuwevakantiewekker != null) {
items["wekker_eerstvolgende"].sendCommand(nieuwevakantiewekker);
function vakantieWekkerInstellen() {
if (wekker_vakantie.isUninitialized) {
var melding = "De vakantiewekker is geactiveerd, maar niet ingesteld...";
return null;
} else {
var uur = String(time.toZDT(items.wekker_vakantie).hour()).padStart(2, "0");
var minuut = String(time.toZDT(items.wekker_vakantie).minute()).padStart(2, "0");
var nieuwevakantiewekker = time.toZDT(uur + ":" + minuut).plusDays(1);
wekker_vakantie.sendCommand(nieuwevakantiewekker);
wekkersmorgen["vakantiewekkermorgen"] = true;
return nieuwevakantiewekker;
function meldingDBE(melding) {
function main() {
if (event.eventType == "time" || event.eventType == "manual") {
wekkerVoorMorgen();
} else if (event.itemName == "wekker_vakantiewekkers_actief") {
main();
The same context as described in my earlier post still applies, beside from the fact that DateTime Group Item eenmaligewekkers now only contains “one-off” alarm clock DateTime Items. I also added a trigger:
triggers:
- id: "1"
configuration:
time: 18:00
type: timer.TimeOfDayTrigger
- id: "4"
configuration:
itemName: wekker_vakantiewekkers_actief
state: ON
