Hello
I would like to know if it is possible to send commands to the BOT from openhab. I made this rule:
rule "test telegram"
Item test received command
val String test_command= "/ledon"
sendTelegram("bot2", "" + test_command )
writes the command to the chat, but does not run. If instead I write /ledon in the telegram chat it works, and it turns on the led.
Thanks for your help
David
I should have understood the problem.
The ESP receives the command if I send / ledon
In fact in the chat appears my name that sends the message to the BOT.
If instead it is OH to send / ledon the command is written in the chat, but without a user and the ESP does not see the command.
I do not understand if it depends on the sketch or it’s a limitation of telegram with OH
Google arduino/ESP receive telegram message. That should come up with some example code.
But I don’t know if it’s possible. Telegrams are encrypted and encryption is memory heavy and computationally intensive. Maybe too much for arduinos and ESPs.
