Hi everyone!
I have a problem, I’m trying to control my air conditioner by sending an infrared signal from my ESP8266 and controlling it via MQTT.
The problem I have is that, as you can see below, my arduino code receives “ON”-“OFF” command to turn on or off the air but the switch I have in my OpenHAB sends 0 or 1, I have tried to use the MAP transformation in several conbinations but without success, I can’t get OpenHAB to send ON or OFF to my ESP8266
My initial setup is:
Arduino
#include <Arduino.h>
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "xxx";
const char* password = "xxxx";
const char* mqtt_server = "xxxx";
const uint16_t kIrLed = 4;
IRsend irsend(kIrLed);
WiFiClient espClient;
PubSubClient client(espClient);
uint16_t TEMP17[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP18[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP19[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP20[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP21[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP22[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP23[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP24[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 4497, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP25[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP26[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP27[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP28[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP29[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 4497, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t TEMP30[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t Off[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433};
uint16_t On[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
void setup() {
pinMode(BUILTIN_LED, OUTPUT);
// digitalWrite(BUILTIN_LED, HIGH);
irsend.begin();
//#if ESP8266
// Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
//#else // ESP8266
//Serial.begin(115200, SERIAL_8N1);
//#endif // ESP8266
Serial.begin(115200);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected - ESP IP address: ");
Serial.println(WiFi.localIP());
void callback(String topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
int i=0;
for (i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
Serial.println();
if(topic=="esp1/habitacion/aire"){
Serial.print("Estado del aire: ");
if(messageTemp == "ON"){
irsend.sendRaw(On, 199, 38);
Serial.print("Encendido");
client.publish("esp1/habitacion/aire/state","ON");
else if(messageTemp == "OFF"){
irsend.sendRaw(Off, 199, 38);
Serial.print("Apagado");
client.publish("esp1/habitacion/aire/state","OFF");
if(topic=="esp1/habitacion/aire/temperatura"){
Serial.print("Temperatura del aire: ");
if(messageTemp == "17"){
irsend.sendRaw(TEMP17, 199, 38);
Serial.print("17º C");
client.publish("esp1/habitacion/aire/temperatura/state","17");
else if(messageTemp == "18"){
irsend.sendRaw(TEMP18, 199, 38);
Serial.print("18º C");
client.publish("esp1/habitacion/aire/temperatura/state","18");
else if(messageTemp == "19"){
irsend.sendRaw(TEMP19, 199, 38);
Serial.print("19º C");
client.publish("esp1/habitacion/aire/temperatura/state","19");
else if(messageTemp == "20"){
irsend.sendRaw(TEMP20, 199, 38);
Serial.print("20º C");
client.publish("esp1/habitacion/aire/temperatura/state","20");
else if(messageTemp == "21"){
irsend.sendRaw(TEMP21, 199, 38);
Serial.print("21º C");
client.publish("esp1/habitacion/aire/temperatura/state","21");
else if(messageTemp == "22"){
irsend.sendRaw(TEMP22, 199, 38);
Serial.print("22º C");
client.publish("esp1/habitacion/aire/temperatura/state","22");
else if(messageTemp == "23"){
irsend.sendRaw(TEMP23, 199, 38);
Serial.print("23º C");
client.publish("esp1/habitacion/aire/temperatura/state","23");
else if(messageTemp == "24"){
irsend.sendRaw(TEMP24, 199, 38);
Serial.print("24º C");
client.publish("esp1/habitacion/aire/temperatura/state","24");
else if(messageTemp == "25"){
irsend.sendRaw(TEMP25, 199, 38);
Serial.print("25º C");
client.publish("esp1/habitacion/aire/temperatura/state","25");
else if(messageTemp == "26"){
irsend.sendRaw(TEMP26, 199, 38);
Serial.print("26º C");
client.publish("esp1/habitacion/aire/temperatura/state","26");
else if(messageTemp == "27"){
irsend.sendRaw(TEMP27, 199, 38);
Serial.print("27º C");
client.publish("esp1/habitacion/aire/temperatura/state","27");
else if(messageTemp == "28"){
irsend.sendRaw(TEMP28, 199, 38);
Serial.print("28º C");
client.publish("esp1/habitacion/aire/temperatura/state","28");
else if(messageTemp == "29"){
irsend.sendRaw(TEMP29, 199, 38);
Serial.print("29º C");
client.publish("esp1/habitacion/aire/temperatura/state","29");
else if(messageTemp == "30"){
irsend.sendRaw(TEMP30, 199, 38);
Serial.print("30º C");
client.publish("esp1/habitacion/aire/temperatura/state","30");
Serial.println();
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect("ESP8266Client")) {
Serial.println("connected");
client.subscribe("esp1/habitacion/aire");
client.subscribe("esp1/habitacion/aire/temperatura");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
void loop() {
if (!client.connected()) {
reconnect();
if(!client.loop())
client.connect("ESP8266Client");
.things
Bridge mqtt:broker:mosquitto "Mosquitto" @ "System" [ host="192.168.0.15", secure=false ]
Thing topic aireacondicionado "Aire" {
Channels:
Type switch : aireonoff [ commandTopic="esp1/habitacion/aire"
// transformationPattern="MAP:ONOFF.map"
//retained=true,
stateTopic="esp1/habitacion/aire/state"
Type string : aireonoffstate [ stateTopic="esp1/habitacion/aire/state"]
.items
Switch Aireprueba {channel="mqtt:topic:mosquitto:aireacondicionado:aireonoff"}
String Airepruebastate {channel="mqtt:topic:mosquitto:aireacondicionado:aireonoffstate"}
Note: I’ve deleted the transformation and other alternatives I tried to simplify a bit.
